You should program the PSU for 10V/5A and the eload to 10V 5A, then 10V .05A alternating say at 1 sec intervals, and check if the PSU actually produces that output and the response waveforms; this can be very stressful on PSU and can damage them if you do this for long periods. That load will simulate radio transmission [ or cellphones if you set it to 3.5V instead] alternating between send and quiescent.
I had try dynamic load as you suggest
DS load (CC) 5A@1s // 0.05A@1s
PSU 10V@5A, but when turn it on, Voltage drop to 0.234V
so i increase current to 5.05A
![](http://img407.imageshack.us/img407/9518/nvwk.jpg)
anyway, how to set PSU for Constant Voltage ?
Switch-on performance with 5A load (5.010A @ PSU)
![](http://img194.imageshack.us/img194/4130/3naw.jpg)
Switch-on performance with 5A load (5.015A @ PSU)
![](http://img809.imageshack.us/img809/9243/c78m.jpg)
Switch-on performance with 5A load (5.020A @ PSU)
![](http://img90.imageshack.us/img90/7192/o1us.jpg)
Switch-on performance with 5A load (5.025A @ PSU)
![](http://img46.imageshack.us/img46/1238/7drs.jpg)
Switch-on performance with 5A load (5.030A @ PSU)
![](http://img844.imageshack.us/img844/8108/uv4j.jpg)
Switch-on performance with 5A load (5.040A @ PSU)
![](http://img132.imageshack.us/img132/9782/pxzo.jpg)
