Author Topic: Maynuo eload speed tests  (Read 2319 times)
Offline HarvsTopic starter
« on: May 28, 2014, 11:59:14 am »
Posting this here incase anyone is interested.
Someone on another forum asked me about the max update speed for the Maynuo electronic load, so I wrote a couple more test scripts for the library:
https://github.com/harvie256/MaynuoPy
Anywho, results were a max update rate of 125 updates/sec.
Chanel 1 below is the current output on the back of the Maynuo, and channel 2 is the 115200 serial line.
Speed test is changing from 1A to 2A square wave.
Offline HighVoltage
Re: Maynuo eload speed tests
« Reply #1 on: May 29, 2014, 12:53:03 pm »
That is a nice test you did.
I just tested a buck converter with the Maynuo, 12V input, 18V output at up to 15A
During the test, I went up to 50 updates/sec. and was surprised, how stable the Maynuo was.
Absolutely amazing!
In contrast, I also have a BK-Precision eload and that one was only stable up to 10A.
And the BK-Precision instrument was twice as much $$
« Reply #2 on: May 30, 2014, 12:21:16 am »
Really, as in the 8500?  Surprises me that there's much difference, I thought they were pretty much the same hardware?
I'm interested in what conditions it was unstable under.  Generally speak for a CC load to become unstable it needs a source with a lot of series inductance such as long connecting cables.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #3 on: May 30, 2014, 02:00:48 pm »
Eloads working with high amps will tend to oscillate.   Keeping leads shortest and placing a rated capacitor on the input will change the RLC relationship and usually fixes the problem.
Best Wishes,
 Saturation
« Reply #4 on: May 31, 2014, 02:56:44 am »
I take it one step further and have some cap and resistors setup to do this.  Just low value resistors, like 100mOhm, in series with a few uF cap works wonders as a snubber.
