I was able to get around to putting together what I felt was a proper review of this product. Note: I have never reviewed a PSU before and took hints from some of Dave's videos reviewing programmable linear supplies like the Rigol DP832 and Atten.
The Matrix MPS-3033X looks to be a clone of the BK Precision 9130B (or equivalent) and has (on paper) the same spec claims, so I used one for comparison. I also used a BK Precision 8600 programmable load and an in calibration Fluke 289 DMM.
![](https://m.media-amazon.com/images/I/41cDg2nvNZL._AC_SY580_.jpg)
I got this unit from
Amazon for $299 with a 25% off promotion (retails for $399).
Lets get into it.
Initial observations:
- The BK Precision is listed at a 30V@3A/30V@3A/5V@3A for CH 1/2/3 respectively. However, the unit actually lets you set 31V@3.1A/31V@3.1A/6V@3.1A.
- The Matrix is also listed as 30V@3A/30V@3A/6V@3A for CH 1/2/3 respectively. However, the unit actually lets you set 32V@3.2A/32V@3.2A/6.2V@3.2A
- The Matrix has a larger and brighter display
- The software is nearly identical (how the unit is controlled, the menu, the features). The only difference I have seed so far are subtle things like setting change confirmation messages.
- Both units have the same IO (USB, RS232, and sense for all three channels), except the BK also has a GPIB port.
- Form factor is identical and dimensionality is identical.
- The Matrix has louder relays and didn't use the standard 0.750" post separation (for BNC adapters)
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
- The banana cables it comes with are ok, but the alligator ends are not great.
For my comparison, I tested the following:
- Supply Power Up transients before outputs are enabled (no load) - DEPRECATED, SEE SECTION NOTE
- Supply Power Up transients before outputs are enabled (10Ω) - DEPRECATED, SEE SECTION NOTE
- Open Circuit Voltage Accuracy
- Loaded Accuracy (indicated vs measured)
100mA
1A
2A
3A - Open Circuit Power up ramp measurement
1V
5V
10V
20V
30V - 1Ω stress test and recovery (Dave's favorite)
- Pk-to-pk Open Circuit voltage noise
- CC (1.3A) for 40W transient power ramp
- Time to transition to CC mode (4A load)
- Channel Off Transients (30V, 1.3A load)
- Supply Off Transients (30V, 1.3A load)
- Supply Off Transients (5V, 1.3A load)
- Supply Off Transients (3.3V, 1.3A load)
- Supply Off Transients (3.3V, 5V-30V AC Coupled in 5V increments, 1.3A load)
1. Supply Power Up transients before outputs are enabled (no load): BK Precision on Left and Matrix on Right
![](https://lh3.googleusercontent.com/FAhQ4WITUUyuSYtQ1pdiEH40WVfy-f1TfIBqmNZq8qXz_-gBzlIqm5Bhv3EYcXWPS48=w700)
There looks to be some trivial activity on the outputs of both units when they are powered up (outputs off), but the amplitude is very low and only lasts a few hundred nanoseconds.
NOTE: As another member below has pointed out, these are EMI spikes from the supply and not on the output. I will leave the content to maintain the list, but I think this can safely be dismissed.2. Supply Power Up transients before outputs are enabled (10Ω load connected): BK Precision on Left and Matrix on Right
![](https://lh6.googleusercontent.com/uA3Ve00KPCsIK5za2B_5szXC05nAY3gnGBvYXk11pJ-uxVDUEWlo6nqOerh32Js5ANw=w700)
Again, similar results with an active load connected.
NOTE: As another member below has pointed out, these are EMI spikes from the supply and not on the output. I will leave the content to maintain the list, but I think this can safely be dismissed.3. Open Circuit Voltage Accuracy:
4. Loaded Accuracy:
5. Open Circuit Power-up Ramp: BK Precision on Left and Matrix on Right (
Note - BK ramps much slower so time base is 10ms vs Matrix 1ms)
![](https://lh3.googleusercontent.com/hwhedRAHvdMU6B0CgiypDch9TLgRRAfdK2oc8dnXNL9tiCZ5vqDXpaPNcE-bV28jluc=w700)
Above shows the ramp for a 1V output.
![](https://lh5.googleusercontent.com/9I1ziHckQwUGDTU1tfGbeFWDEbmRidGQlZkQpoe8_tLzN7-zI_F7m62Y6QTSq4toxeY=w700)
Above shows the ramp for a 5V output.
![](https://lh6.googleusercontent.com/uRhu3J8dO6kt27Jnx2MfrU6_biB6xWAKwX0H3vPHzzZI7P4iutnkPaGAK1rQt3zQ4ao=w700)
Above shows the ramp for a 10V output.
![](https://lh6.googleusercontent.com/XMH64G-eabOK1PGDnXqgj6Th-qXH09fjScuXcgCWfKG_QnUQhh638EtGmIZOZJeBBEU=w700)
Above shows the ramp for a 20V output.
![](https://lh3.googleusercontent.com/STmi0K7JzQyVzgaCJDcF9iML9rw7XIk27ZtJpq7ndMidxXsRW97jvH07c4pArc4QPeE=w700)
Above shows the ramp for a 30V output.
6. 1Ω Stress Test and Recovery: BK Precision on Left and Matrix on Right
![](https://lh4.googleusercontent.com/oNw-DAWk7HQwnH5IUF9vWuUlo3ugnHeASJVts9Qbsb8OEKSg5zKVfSeCHRdvWjLDXpk=w700)
Both units went into constant current mode and did not oscillate between CV and CC mode. I even made sparks by shorting the channel out with banana leads over and over again. It would immediately click into CC mode and drop to ~50mV.
7. Pk to Pk Open Circuit Noise: BK Precision on Left and Matrix on Right
![](https://lh4.googleusercontent.com/X9V2CvZUz-5HfZ4IDp8Q0xhcujuUH7tJfOv2QquWWVrv4pqaa_7mwQBeqIZpyNeRYUk=w700)
8. 1.3A (~40W) Constant Current Power Up Transient: BK Precision on Left and Matrix on Right
![](https://lh3.googleusercontent.com/2ozCYIZ5bCDBndOfAY2tUBc488NG_ASocTrww6kC1LEynovNfa3w0E0NOIX_VJCZPcg=w700)
Both units went into constant current mode and held there when I used the constant wattage mode on the programmable load, so I used a CC of 1.3A. This comparison also shows the difference in ramp up rate.
9. Time Delay to Transition from CV to CC mode: BK Precision on Left and Matrix on Right
![](https://lh3.googleusercontent.com/yqw9LpgRvbvVWCZOTZuZ8eQH_WV8768sN_Ed4ckMzT1kQ1nnsbnUnaazkQjYQUu7v5E=w700)
Both units went into constant current mode in 800us.
![](https://lh5.googleusercontent.com/t6C-nxJSW8y-6beHYN_OJ9D3iE5cCOAJ1PHQCwHrJerzyb2ECUBgQAX8pjPf_SS4twM=w700)
The Matrix had a slightly more aggressive drop in voltage.
10. Channel Off Transients (30V, 1.3A): BK Precision on Left and Matrix on Right
![](https://lh5.googleusercontent.com/W2yCQNl8zHXyacW8aPu4gZVUkMxbeyDyb81d_d_aa0BPv9ny7fmOGTdTH1Um9RLO67I=w700)
The channel output is about the same between the two units when enabling and disabling the channel with the BK being a bit more consistent as the slope doesn't change, but that doesn't matter. Both units have a safe channel power off transition with no spikes or concerning transients.
11. Supply Off Transients (30V, 1.3A): BK Precision on Left and Matrix on Right
![](https://lh3.googleusercontent.com/agjAYsolXGp5i5oHGJ9x0mOt8cxiA1j80VhfQ9k_fWMGuBdPBOImiWZwHCq08jD002g=w700)
The channel output with powering off the entire supply (while under load) is a bit different between the two units, however both have very fast and clean power drops.
12. Supply Off Transients (5V, 1.3A): BK Precision on Left and Matrix on Right
![](https://lh6.googleusercontent.com/Qnz8L6xCd48F-TFI0KT7G9xVmg7jYNQucBHkbOaW8MjEOPGl_NlcQHpjJSMa2OgjTjA=w700)
The Matrix seems to ramp up an additional 0.2V (over ~23ms) before discharging when active shutdown occurs with a 5V output which is not present in the Matrix.
13. Supply Off Transients (3.3V, 1.3A): BK Precision on Left and Matrix on Right
![](https://lh3.googleusercontent.com/BHfPDahYj9xms_KS1ghS4B0UUwzKud4fkPfzaLE1nNOoP_zx_YS7InpCV8K7qh6e0yY=w700)
The BK seems to have a small transient just before discharge at 3.3V that is not present in the Matrix.
Below is a zoomed in view of the short transient present on the BK during the active 3.3V shutdown
14. Supply Off Transients (3.3V, 5V - 30V AC Coupled in 5V increments, 1.3A): Below shows the AC coupled power transients of the Matrix supply to get a better look.
- 3.3V: No transient detected.
- 5V: 26.4ms ramp up to 162mV overshoot
![](https://lh4.googleusercontent.com/i68VGrlWulaph0X4MY96y8eP5RIUaaw07yMKURUDbHkWeqpmzmjdltZy0i97sRWTkT8=w700)
- 10V: 22.8ms ramp up to 152mV overshoot
![](https://lh3.googleusercontent.com/PGOFcvcqFJHHiZyIZdgLxC_R1lCpdjrWX5_XtP0gkPCt8U6_e-Q4mTVA_v-w52TbRnE=w700)
- 15V: 48.2ms ramp up to 244mV overshoot
![](https://lh4.googleusercontent.com/plDCYr0iPFNnKbM9A_pYz63JUyj-bZa2BHmSZ1iF39phIQ6SPghtH-hccOivaasaZSY=w700)
- 20V: 48.2ms ramp up to 276mV overshoot
![](https://lh5.googleusercontent.com/Q3cEBfGzoPf1cNn6KxW8r73fekhUk_cw-b-nuba-00iv3TMq1uG2AM5cmQZl1Z92sHg=w700)
- 25V: 49.8ms ramp up to 284mV overshoot
![](https://lh4.googleusercontent.com/9NatNZ1CDoCUdfk4DMCB4D-mAb64g0hwrY8Yiy2a-lwYXheKOFPDEddBMgbIGT5jvNM=w700)
- 30V: 54.4ms ramp up to 288mV overshoot
![](https://lh3.googleusercontent.com/_b_AF2eXpLtBPSitNBQVZL3Hmg6y_QNdYbtUSp3k-4LyCvgHd0C4_86wDDdRplnI8T8=w700)
The Matrix supply ramp up lasted ~26ms to ~55ms depending on the output range and ramped up to ~160mV to ~290mV depending on the output range (> 5V).
Below is a plot summary of the voltage overshoot peaks based on the output voltage to interpolate the intermediate values. (3.3V is at 0V overshoot)
![](https://lh5.googleusercontent.com/TK0WTM_g7EpGtPsi4sfeM8UfSCJ4Vu_5kExwVKUFIcX2YKp2QRGUv6Ari475JpWJZK8=w2400)
This was masked in the section 11 testing due to the voltage range of the signal and DC coupling it. This characteristic is something to keep in mind, but I don't think its a concern. Also, keep in mind that I measured the overshoot peak, which is not the active level during the entire ramp up time. Please comment if you disagree!
Overall, I am pretty impressed. There are a few things that I think I could evaluate better. If anyone has any suggestions, I would be happy to experiment further!
