Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Probe for oscilloscope Tektronic 2201
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Probe for oscilloscope Tektronic 2201 (Read 1363 times)
decoder_82
Regular Contributor
Country:
on:
March 08, 2022, 08:49:30 am »
I have an oscilloscope Tektronic 2201 (20 MHz) but I don't have a probe for it.It is supposed to come with a prove P6103 which is not so easy to find.
From here
https://w140.com/tekwiki/wiki/2201
It is expecting input impedance with 1 MΩ and 25 pF.
I found a P6103
B
which I think will not work as the manual says "bandwidth not less than 60 MHz"
What would be suitable probe for this model ?
Thanks in advance !
Logged
Jeff eelcr
Frequent Contributor
Country:
Re: Probe for oscilloscope Tektronic 2201
Reply #1 on:
March 08, 2022, 12:06:43 pm »
P6103B is the recomended 10x probe for that unit, Tektronix 2201.
Jeff
Logged
decoder_82
decoder_82
Regular Contributor
Country:
Reply #2 on:
March 08, 2022, 03:55:19 pm »
Thanks ! so actually I did not dug enough and indeed the recommended probes for this scope are:
- P6103B (10x 60MHz)
- P6119B (1x/10x 10/100MHz)
- P6101B (1x 15MHz)
Logged
bdunham7
Super Contributor
Country:
Reply #3 on:
March 08, 2022, 04:10:08 pm »
Quote from: decoder_82 on March 08, 2022, 08:49:30 am
Almost any cheap probe will work fine with that. The 1M/25pF input just means that any 10X probe needs to have a compensation range that goes up to 25-30pF, which most low-end probes will. More expensive probes might have a lower compensation range and not work properly. For 1X it just doesn't matter, they will all work fine.
Logged
A
3.5 digit
4.5 digi
t
5 digit
5.5 digit
6.5 digit
7.5 digit DMM is good enough for most people.
decoder_82
decoder_82
Regular Contributor
Country:
Reply #4 on:
March 09, 2022, 04:57:02 am »
Thanks then my cheap clone P6100 probe should work fine.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
