Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Tektronix TDS3000B RTC running slow
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Tektronix TDS3000B RTC running slow (Read 1442 times)
perdrix
Frequent Contributor
Country:
on:
March 20, 2020, 01:09:40 pm »
I know it's not a major issue, but has anyone hit this problem and found a resolution?
I suspect it's probably a trimmer or firmware controlled varicap that needs tweaking, but ...
TIA David
Logged
voltsandjolts
Supporter
Country:
Re: Tektronix TDS3000B RTC running slow
Reply #1 on:
March 20, 2020, 02:02:17 pm »
The RTC is a sealed DIP module by Dallas/Maxim with internal battery and some NVRAM in it too.
The battery in your module is likely failing.
Some folks have hacked them open and replaced the battery.
Otherwise you need to source a new one...which is a bit of fun because there are lots of fakes around.
The bad news is they are soldered into the main board, I added a socket when I changed mine out.
The good news is there is no critical info in the NVRAM, so you can just fit a new blank one. IIRC the operating hours gets reset to zero.
https://www.eevblog.com/forum/testgear/tek-tds3000-series-and-dallas-nvram/
https://www.digikey.co.uk/product-detail/en/maxim-integrated/DS1742W-150/DS1742W-150-ND/951280
https://www.ebay.co.uk/sch/ds1742w
Last Edit: March 20, 2020, 02:13:00 pm by voltsandjolts
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
