Author Topic: Magnova oscilloscope  (Read 119117 times)
AgiRigSig, ADT123, bux98 and 8 Guests are viewing this topic.
Online joeqsmith
Re: Magnova oscilloscope
« Reply #375 on: September 12, 2024, 09:01:57 pm »
The 1 M input termination must be used with the supplied passive probes.
Reading the manual, is the above statement accurate?  Does the scope have proprietary 10x probes that must be used?   Other probes that would meet the required compensation are not supported?
After reading the manual, there are a few minor things that may need cleaned up but these could be from running the translator (see previous post for attached English translation).   For my purposes, this manual was good enough.
It's one thing to read how that UI works but I think I would just need to try and run it.   Having used a mechanical UI since my first Dumont oscilloscope, I can see really liking it or hating it.
The one thing I really see missing is a programmers manual.   I commonly will use test equipment as part of a larger test and am used to rolling custom software to automate them.  I would like to see this interface well documented.  I also would like to see metrics published on what sort of data transfer rates we could expect.
All in all,  it looks good and I am still very interested.   Get that thing certified for sale in the USA or just ship one of the prototypes and lets have a look.
« Last Edit: September 12, 2024, 09:21:17 pm by joeqsmith »
Online Martin72
  • Testfield Technician
« Reply #376 on: September 12, 2024, 09:11:53 pm »
Where did you find this, which page?
(Kierkegaard)
Online Martin72
« Reply #377 on: September 12, 2024, 09:25:11 pm »
I found it(page17).
It only says that you have to switch the input to 1M if you want to use the supplied probes.
Which makes sense, because they are designed for 1M.
(Kierkegaard)
Offline egonotto
« Reply #378 on: September 12, 2024, 09:40:04 pm »
Hello,
there must be a few owners of a Magnova by now. It would be nice if one of them would write here.
Best regards
egonotto
Offline egonotto
« Reply #379 on: September 12, 2024, 09:54:36 pm »
Hello,
Question for Batronix and Martin72:
@Batronix: Is it possible to operate the Magnova from remote via internet?
If so, you could connect an interesting signal to each input and give Martin72 access for a certain time.
@Martin72: Would you participate?
Best regards
egonotto
Online ebastler
« Reply #380 on: September 12, 2024, 10:12:47 pm »
I'm not sure that would that do justice to a scope where the UI is one of the distinguishing features. You could not really experience the user interface with the large screen and the four flexible rotary encoders right next to it, acting as "soft knobs". And you could not experience screen update rates and smoothness (or lack thereof) when moving things around either.
These aspects don't matter that much if you are purely after an "analytical scope". But my feeling is that the Magnova -- while hopefully providing comprehensive and accurate measurements and analytics -- puts a lot of focus on interactive use and how that handles and feels.
Online joeqsmith
« Reply #381 on: September 12, 2024, 11:03:46 pm »
I found it(page17).
Note the quotation, this was copied from the Google translated manual verbatim.   So, are you suggesting that this is a problem with the translation and that the original language tells us something different?   This would make sense but I have no way of knowing, which is why I asked.
Offline egonotto
« Reply #382 on: September 12, 2024, 11:26:17 pm »
Hello,
On page 17 under 4 it says: “Bei den mitgelieferten passiven Tastköpfen muss die 1 MΩ Eingangsterminierung verwendet werden”.
This means that if you use the supplied passive probes, than you must set the input to 1 MOhm.
It does not say that you have to use the supplied probes. So this is no different to most other scopes.
Best regards
egonotto
Online joeqsmith
« Reply #383 on: September 12, 2024, 11:44:13 pm »
Ok, so a Google translation problem.   Thanks as I was thinking this was going to be a deal breaker.   Imagine a scope that couldn't use standard 10X probes.... :-DD
Offline LoneWolf6912
« Reply #384 on: September 13, 2024, 05:27:00 am »
Sadly, I still didn't received the scope.
Offline DK3BH
« Reply #385 on: September 13, 2024, 05:38:20 am »
At least I can confirm: Its real and it works :)
I received my magnova scope yesterday.
The boottime is rather quick (~29 seconds) and the unit is well put together.
The display is indeed really crisp and the UI seems even more responsive than the UI of the Tektronix Series 5 we have at work.
Any suggestions what I should test first during the weekend?
Its always impossible until its done.
Online Martin72
« Reply #386 on: September 13, 2024, 07:14:15 am »
Looks like a TV....
(Kierkegaard)
The following users thanked this post: egonotto, RAPo, moerm
Offline woody
« Reply #387 on: September 13, 2024, 08:06:38 am »
Looks like a TV....
Go wash your mouth!  ;D
The following users thanked this post: RAPo
Offline FloBX
« Reply #388 on: September 13, 2024, 01:22:31 pm »
The English-language manual is almost ready and will also be made available online in a few days.
Looking forward to reading it.
An English-language manual is now available at https://www.batronix.com/magnova/en/downloads or via the Magnova product pages.
We will need a few weeks before we can provide documentation of remote control features (Rest API/USBTMC/HiSLIP/Raw). We have just joined the LXI Consortium but do not yet have a certified product.
Looks like a TV....
I personally prefer applying some tilt to the screen. ;)
We are now looking forward to the first customer feedback. Thanks to DK3BH so far!
Best regards,
Florian
(Batronix)
The following users thanked this post: egonotto, joeqsmith, Andre77
Online nctnico
« Reply #389 on: September 13, 2024, 01:24:54 pm »
Looks like a TV....
Learn to recognise a compliment  :) If it looks like a TV, it has a very high WAF https://en.wikipedia.org/wiki/Wife_acceptance_factor
The following users thanked this post: egonotto, tooki, KungFuJosh, Martin72, FloBX
Offline woody
« Reply #390 on: September 13, 2024, 02:03:51 pm »
Looks like a TV....
But is that what you really want? Honey, that tiny TV set you left on your desk, that did not work. I tried it but only got static on all channels. As I was going into town anyway I dropped it at the recycling plant for you. Saves you a ride, no? >:D
Offline egonotto
« Reply #391 on: September 13, 2024, 02:19:08 pm »
Hello,
have fun with the Magnova.
What bandwidth does your device have?
Did you buy a function generator with it?
Did you buy one or two logic probe sets?
How do you cope with the position of the BNC connectors on the right?
Best regards
egonotto
Online joeqsmith
« Reply #392 on: September 13, 2024, 04:29:00 pm »
Thank you for turning around that English manual so fast.   It is much better than the Google translated version.
For the software interface manual,  even if you just have a list of the basic commands and not the full documentation, I would like to see it.  Just to have some idea how to interface with it.
In the long term, do you plan to provide sample test software in various languages to get people started with writing their own custom software?
I notice your avoidance to respond to my question about availability to the USA.  If certification is the concern and you would like to have it tested, maybe we could help out.  Shoot me a PM if interested and we can talk about it.
Online Martin72
« Reply #393 on: September 14, 2024, 06:17:03 am »
Well, I guess I will too, then.
(Kierkegaard)
Offline DK3BH
« Reply #394 on: September 15, 2024, 08:13:32 pm »
Hello,
Best regards
egonotto
I brought the 200 MHz version of the Magnova.
So far I didn't go for the optional wave-gen, because I already own an old Marconi signal generator which can do all modulations I need.
But I ordered one of the logic analyser probes, but they seem to be delivered later.
My model showed a -3dB point around 334 MHz when directly supplied by the signal generator.
It was around 194 MHz when using the supplied probes.
Those are a good step up from the ones which came with my Siglent SDS2104x plus.
They have a much better feel of quality to them.
I'am still not convinced by the side mounted BNC connectors.
When using my scope, I mostly use hands free probes.
And so far the front BNCs on a "traditional" scope were never an issue for me.
The somewhat odd shape takes away more bench space, but there are VESA mounting holes on the back.
Maybe I will get a small arm to have it floating above the bench.
A point to keep in mind: The Magnova gets quite warm during operation.
You can see it in the offset drift in the lower voltage ranges.
That settles around 30mins and in the mean time, an offset cal fixes the issue.
Best regards,
DK3BH
The following users thanked this post: pmcouto, egonotto, DaneLaw, Geofrey
Offline Geofrey
« Reply #395 on: September 15, 2024, 08:28:09 pm »
Thanks for the first impressions.
How do you like the UI ? And the scope so far overall ?
Do the noise look consistent with the datasheet values ?
How responsive is the FFT ?
Best,
Online nctnico
« Reply #396 on: September 15, 2024, 08:50:50 pm »
Looking at the screenshots I must say that I'm missing a clear distinction between information and buttons. It is because I know what should be buttons and what should be information, I can tell the difference but I think some differentiation in the graphical representation would be nice.
Offline DK3BH
« Reply #397 on: September 15, 2024, 09:15:45 pm »
The UI is a bit overwelming at first. Its much easier when you sit in front of it and can just fiddle around with the touch screen ;)
The UI itself is super responsive.
Even with low waveform update rates, the scope remains responsive (that really bugged me out on my former siglent scope).
I will try to get you guys a small video from the UI interaction (and measure the noise floor as well) when I'am back from the office tomorrow.
Till now I'am quite happy the the scope.
The following users thanked this post: pmcouto, egonotto, tooki, jusaca, Geofrey
Online nctnico
« Reply #398 on: September 15, 2024, 09:46:33 pm »
I'm also noticing something I call 'trigger lensing'. Around the trigger point, the trace gets thinner but beyond that, it get much thicker. I don't think this is a true representation of the signal as noise around the trigger point makes the trace move left/right more than it should. A trigger condition should be targeted at an edge of a signal (IOW a section of the signal) around the trigger level crossing which to some extend (=the trigger hysteresis boundaries) cancels noise, not just the single point where the signal crosses the trigger level. Maybe this can be adjusted with a trigger hysteresis setting.
« Last Edit: September 15, 2024, 10:23:01 pm by nctnico »
Offline DK3BH
« Reply #399 on: September 16, 2024, 12:16:32 pm »
Thats interesting. Is there a paper about that topic to dive a bit deeper?
I saw that issue on various oscilloscopes but never saw that as an issue.
I thought its something related to the sample rate / waveforms per second update rate ratio and never thought about it in detail.
But I put our mighty Tek Series 5 scope at the office though the same challenge and even here its visible (but of course at a much lower extend):
