Interesting fact: maximum input is 30 pk for 50 Ohm input - 18 W. Either Magnova has impressive technology or bug in datasheet.
ENOB is provided even for 5 V/DIV at 50 Ohm, suggesting even higher input.
The 50 Ω input is specified with 5 Vrms, 30 Vpk (0.5 watts). Short peaks of up to 30 Vp are permitted as long as the 5 Vrms are maintained.
Vertical scaling is not limited even with 50 Ohm input termination. This allows, for example, that two channels can be displayed with the same scaling (5 V/div), even if one of the two is terminated with 50 ohms. However, regardless of the vertical scaling, you must observe the maximum voltage when using the 50 Ohm termination.
I find magical that channels 1&2 have 1.6 GSa/s while 3&4 have 1.0 GSa/s and those channels cause drop on channel 1&2. Oscilloscopes with two dual channel ADCs tend to be symmetrical and divide sampling by two not fractional...
We use a 4 channel 1.6 GSa/s 12 bit ADC from TI. The limitation to 1 GSa/s with 4 active channels does not come from the ADC, it comes from a limitation of the maximum data processing rate in the FPGA/RAM. Rate limitation is achieved directly through reduction of sampling clock frequency.
I suspect that there is an error in the calculation of the ENOB in the data sheet (version 0.91). It is probably calculated with Vpp instead of Vrms. The influence of the clock signal does not seem to have been taken into account either.
The ENOBs were calculated on the basis of the Vrms noise values. Where do you see a mistake? I have validated this briefly at 100 mV/div and come up with the same result as in the data sheet.
SNR: (8 div *100mV/div) / 502µVrms =1593.6
SNR [dB]: 20*LOG10(1593.6)=64.05 dB
(64.05 dB - 1.76 dB) / 6.02 =10.34 bit
do I understand correctly that no USB3 cable is supplied for the connection to the PC?
It's true, we don't currently include a USB 3 cable. I will address this internally.
Ohoh, I'll have to brush up my German then.
The English-language manual is almost ready and will also be made available online in a few days.
