There are people like that, Josh.
I've now taken a closer look at the scope, as it's not really comparable to using a smartphone at work.
Yes...not bad at all.
Maybe there will be a proper data sheet, the brochure provided is just a brochure that I couldn't make any decisions based on.
15.6" Full HD is a word, there's no other way to put it.
A 5-year warranty and microswitches, as well as an ELMA encoder, that's pretty solid.
So about the first impression:
+ 15.6" full hd display
+ 8Mpt FFT
+ Full AWG option with 20Vpp
+ build factor
+ Measured by the wfms/s probably fast hardware
+ comes with Testec probes
- High-quality ELMA encoders, but the buttons look cheap and clunky.
- Hopefully some functions can be switched off, the screen looks very crowded, too much info.
ebastler has already said something about the rather meager sample rate, but for the maximum bandwidth this is probably okay, most of the time.
Otherwise a good impression for the money - NOW.
But don't forget that this is an introductory offer.
After that, the 350Mhz model will cost €7078 (incl. VAT).
This means that it already competes with the 6000 from Siglent, as well as various "real" entry-level models from renowned brands such as Lecroy and Tektronix.
