Author Topic: Magic smoke blows up! 34401A  (Read 4018 times)
Offline dimmogTopic starter
    • 34401A Facebook group
« on: October 03, 2021, 06:23:55 pm »
Latest ebay find. Magic smoke blows up here!
Poor HP/Agilent 34401A
The following users thanked this post: joeqsmith
Offline TheSteve
  • Living the Dream
Re: Magic smoke blows up! 34401A
« Reply #1 on: October 03, 2021, 06:27:27 pm »
OK, you win, that is the ugliest 34401A I've seen to date(and I bought one that had a hole drilled all the way through case and board).
« Last Edit: October 03, 2021, 06:38:41 pm by TheSteve »
VE7FM
The following users thanked this post: Zucca, tooki, gnavigator1007, AVGresponding, dimmog
Offline Gyro
« Reply #2 on: October 03, 2021, 06:28:56 pm »
Wow. Did somebody try to measure lightning?  :o
At least the MOVs and Spark gap look intact!  :D
Best Regards, Chris
« Reply #3 on: October 03, 2021, 06:34:04 pm »
Wow, thats fit for the bin, did you buy it and it blew up or what?
Offline strawberry
  • Country: lv
« Reply #4 on: October 03, 2021, 06:38:59 pm »
Challenge accepted
I think, front end should be still alive
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #5 on: October 03, 2021, 06:39:04 pm »
That's just too far gone.
« Reply #6 on: October 03, 2021, 06:52:06 pm »
I bought it on ebay https://www.ebay.com/itm/255153918046
A little worried about the pungent smell of burning right out of the shipping box. :)
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #7 on: October 03, 2021, 07:06:17 pm »
I think your deal stinks.  :-DD
« Reply #8 on: October 03, 2021, 07:15:27 pm »
Wow, you've got to try quite hard to do that much damage to a 34401A.
« Reply #9 on: October 03, 2021, 07:23:08 pm »
Two of the MOVs look intact. There should be a third MOV to the side of the front terminals. I don't think it's there any more!
The following users thanked this post: Gyro
Offline Gyro
« Reply #10 on: October 03, 2021, 07:29:53 pm »
Looking at the first (wider scale) photo in the OP, the third one may actually still be there too.
I wonder if someone seriously exceeded the common mode voltage limit with a high energy source.
« Last Edit: October 03, 2021, 07:31:53 pm by Gyro »
Best Regards, Chris
Offline floobydust
« Reply #11 on: October 03, 2021, 07:35:53 pm »
It carbon tracked and arced to the Front Panel board, all is toast. Exploded PLCC, kapton tape on the electrolytic tops?
Only seen this much carnage with a MOT and someone extra stupid to let it arc for a very long time.
« Reply #12 on: October 03, 2021, 07:51:53 pm »
Good grief... whomever did that should be made to lick the pcb clean.
Whilst it's true anything can be repaired, the time and cost to fix that would be completely impractical. Hopefully there are enough surviving parts to recoup some of your costs!
I wonder if we should add a new award to the TEA thread, "The McCoy Award", or the "Dead Parrot Award" both spring to mind.
Offline bdunham7
« Reply #13 on: October 03, 2021, 07:58:10 pm »
I've been trying to figure out what demented company it is that drills their TE before selling it to the surplus dealers.  Any idea?  And b/t/w, I know first okay, second hand that whoever they are, their selling agent does not disclose that the items have been drilled.
Offline TheSteve
  • Living the Dream
« Reply #14 on: October 03, 2021, 08:00:37 pm »
Kapton tape on top of the electrolytic caps is factory.
"What do we have on the spacecraft that's good?" seems appropriate here.
VE7FM
« Reply #15 on: October 03, 2021, 08:02:24 pm »
Demilitarisation?
Surely not disclosing this sort of thing will result in a marked lack of repeat customers?
Offline TheSteve
  • Living the Dream
« Reply #16 on: October 03, 2021, 08:03:32 pm »
Well in my case it was advertised that a hole had been drilled through the entire thing, and it was pretty obvious looking at the case. That is what made me want it(yeah, I'm broken). Someday I'll post the repair of my Datron 4920M that had been decommissioned by hammer.
34401A repair: https://www.eevblog.com/forum/repair/34401a-repair-(had-a-hole-drilled-through-it)/
I have some parts 34401A PCB's, wonder if a working unit could be made.
« Last Edit: October 03, 2021, 08:05:13 pm by TheSteve »
VE7FM
Online Stray Electron
« Reply #17 on: October 03, 2021, 08:18:11 pm »
   The only place that I've ever seen that done was on De-Militarized equipment.
Offline joeqsmith
« Reply #18 on: October 03, 2021, 09:42:51 pm »
I would like to hear the story behind it.
Offline WattsThat
« Reply #19 on: October 03, 2021, 09:49:35 pm »
I’ll second that. If the person was still upright when it was over, I’ll bet they needed a clean pair of tighty whities.
A Jerry Lee Lewis song lyric comes to mind: “Goodness gracious, great balls of fire”
That had to be several kilovolts to create that area of flash-over, unless the board was contaminated. Even so, it would take some mighty high voltage to do that and more than a few watts required to vaporize that missing MOV. Scary stuff.
Offline joeqsmith
« Reply #20 on: October 03, 2021, 10:17:45 pm »
Looks like the MOVs and GDTs are all there.  The trace may have saved it from further damage.  Maybe the current owner will clean it up and post a few pictures.
Offline WattsThat
« Reply #21 on: October 03, 2021, 11:02:32 pm »
Ah, you’re correct. I thought RV101 was missing but it turns out it is a black device, not the blue, somewhat hidden in the shadows. It does appear that R104 and 105 in the input chain are vaporized, I mistook that area for RV101.
Offline bdunham7
« Reply #22 on: October 03, 2021, 11:12:37 pm »
That's probably the best guess so far.  Perhaps trying to measure the current of a high-voltage source like a MOT or worse?  I'd like to see the case and covers around that area.
Offline MadTux
« Reply #23 on: October 03, 2021, 11:21:35 pm »
In that case, transformer might have arced over inside and inguard logic might be toasted too, first thing I would test is supply inguard with 5V logic voltage and see, if it's shorted. If so, that thing is a paper weight and only useful as a source for case parts, which actually still look quite good  ;D
« Reply #24 on: October 04, 2021, 12:07:13 am »
What are the 2 wires that I circled in Red?
I don't see them on other units.
Looks to me as though someone tried to jump those traces from the underside of the board to the top and connected them improperly.
Not wires, you're seeing the spring on the switch which just happens to coincide with the edges of the area of PCB that's bubbled up.
