Hello all,
I have got an old Russian oscilloscope C1-79 that wasn't working well.(
http://www.izmer-tech.narod.ru/oscil/oscil.html)
With power on, everything looks like ok.
All controls on the front panel appear to function normally.
The two traces appear correctly, brightness and focus going well.
I tried with sinusoidal signal at the entrance A and B, signal was synchronized well.
The oscilloscope works very well until 20 minutes.
After 20 minutes R68(5,1 ohms) from power supply(?22.044.072 ?3) heats very strong.
At the same time happens next:
-transistor T1(2T808A) [?23.211.029 ?3] heats strong.
-current through fusibile ??(2A) [?23.211.029 ?3] rise from 0,34 A to 1,02 A.
-tension bar (27V) - collector T1 [?23.211.029 ?3] decreases from 32 V to 19 V
-brightness and focus decreases very much so the traces disappear.
-fan rotation speed decreases(the pwer supply of the fan is 27 V)
After I power off the oscilloscope and it is getting cold, again the oscilloscope works well.
I checked fan and it is ok.
I checked T1(2T808A), T4(2T602b) C3, C4(1uF)[?23.211.029 ?3] and it is ok.
I untied the terminal 7 from transformer (T?) [?23.211.029 ?3] but still persisted the same defect.
Anyone have any ideas fixing this problem?!
Thank and sorry for my poor english.
