I am doing something kind of basic, which is to check the accuracy of my test equipment.
I have an Agilent E4400B signal generator. I checked its output with an HP 432A for which I have three working sensors. The E4400B seems to be accurate when I measure 2 dBm at 50 MHz and all three sensors agree.
When I make this same input to an HP E4406A Transmitter Analyzer, the measurement is about 1.95 dBm on its spectrum analyzer. This is pretty good, I should think. The other day when I tried this, I did not get as good a result and wondered if it was the coax cable. I have a couple of other instruments (LeCroy WaveRunner 44Xi-A oscilloscope and a JDSU JD747A Signal Analyzer) that I would also like to check.
I just tested again, and the spectrum analyzer measurement on the JD747A is way off (like 12 dBm!) presumably because I don't know how to adjust the settings correctly.
I am not an electronics engineer and have the equipment for ham radio work, mainly. I am still learning!
Richard
