The 7S14 is not useful by itself. So you would be getting a single trace 7A19 and a dual time base 7B92 with the second scope.
Between the two choices, having 2 inputs with the 7A26 and a single time base with the 7B70 is probably a better deal.
The ultimate goal would be to have 4 inputs with 2 7A26 vertical plugins, and a dual time base with 7B70/7B71, or 7B80/7B85, or 7B92. As you know your local markets better than we do, you need to decide how likely it is that you would be able to add an additional vertical plugin and time base in the future.
The flexibility of adding various plugins to the 7904 is an important feature. If you won't be able to acquire any more plugins, then it might be best to not get the 7904.
