As usual we have wandered off track.
As suggested by DaneLaw, I also think that the OWON CM2100B is a good starting point for evaluation, as long as Bluetooth logging is workable.
It has a wide clamp opening (17mm) for heavy cables, and 2A, 20A, and 100A ranges.
Of course you only get the 1mA resolution in the 2A range, and you need to be pretty careful about zeroing in the same magnetic field orientation just before you clamp the cable.
I don't have the Bluetooth version, so I am not sure how easy it is to use, but at a price of about USD $60 it certainly is not a big deal for a business to justify purchase for a trial.
If logging via something like SD card is needed, then the EEVblog 121GW DMM plus a plug in clamp probe would be the way to go.
It might be hard to find a combination which works as well for low currents.
e.g. the ESI 695 has 20A and 80A ranges, with 100mV/A and 10mA/A output, and zeroing is via a knob rather than button press.
Also, SD card removal on the 121GW isn't as easy as one might hope.
