I'm not aware of any low cost ones that can measure 2KV DC/AC. I have no idea what you are trying to measure, but assuming it is low energy CATI, sub kHz sources, there are some high voltage meters available that would cover these ranges. A basic off the shelf probe may be fine.
As Fungus suggests, you could also consider making a homemade attenuator that could be used with any DMM. I've made a few of these and put together a video showing the last one I made. Video gives you some idea about different circuits that could be used and the math to calculate the values.
