Author Topic: Looking for Lecroy Waverunner Xi series service manual  (Read 7958 times)
Online KirkhaanTopic starter
« on: September 01, 2018, 06:38:23 pm »
I've searched the forum and think this has not been asked before:
Does anyone happen to have the service manual for the Lecroy Waverunner Xi series?
Is it available publicly anyhow?
I have a Waverunner 44Xi here from 2006 which has boot issues.
The service manual will make my troubleshooting much easier  8)
Thanks in advance!
Offline abraxa
  • Sigrok associate
Re: Looking for Lecroy Waverunner Xi series service manual
« Reply #1 on: September 02, 2018, 06:29:05 am »
I haven't seen a service manual around. What boot issues do you have? Maybe it's just the hard drive and/or the data on it that's causing them.
« Reply #2 on: September 02, 2018, 08:08:02 am »
I'm getting attached screen at start-up.
After BIOS reset the display works again and shows me a normal startup procedure until "verifying DMI pool data".
After that the screen stays black (also on the VGA output). Normally I would expect the Windows XP start-screen.
So I guess indeed there is something corrupt on the HDD.
I guess I have to start looking into the Recovery Tools and Procedures from Lecroy...
Offline abraxa
  • Sigrok associate
« Reply #3 on: September 02, 2018, 08:38:34 am »
If I were in your situation, I'd do the following:
- make a bootable USB stick (e.g. using LinuxLive USB Creator)
- boot the scope from the USB stick
- copy the hard drive to an external hard drive ("mkdir /mnt/sdb; mount /dev/sdb /mnt/sdb; dd if=/dev/sda /mnt/sdb/lecroy.img" or similar - just be careful, dd can wipe your harddrive if you don't know what you're doing; when in doubt, ask)
- copy the calibration data on D: to the USB stick as well, just to have it in two places because you're in trouble when you no longer have it
- reboot
- unplug the USB drive and USB stick
- follow the recovery instructions: http://cdn.teledynelecroy.com/files/manuals/scope_system_recovery_instructions.pdf
« Reply #4 on: September 02, 2018, 09:26:24 am »
Thanks for your help abraxa! Really appreciate it.
I plan to start working on it next week. Will keep you informed.
Offline Mr Nutts
« Reply #5 on: September 03, 2018, 07:54:55 am »
Maybe this will get me banned but yesterday I talked to a certain former member of this forum who happens to know more about lecroy scopes than anyone else I came across, and I asked him about this problem. This is what he said:
Tell your friend that he should replace the BIOS backup battery (IIRC a CR2025 or 2032, sits on the mainboard) and there's a good chance the scope will be up and running again. If the BIOS battery voltage gets too low the CMOS content gets corrupted which means the mainboard doesn't know the LCD panel any more. That's quite a common problem when these scopes get older, and there's some serious disassembly required (i.e. you have to remove the front end and the acquisition board) to get to the mainboard and the battery to replace it.
BTW, if your friend's scope's handle is blue (like the rear housing) then this means his scope hasn't been with LeCroy for rework where some of the issues of the old (M)Xi Series has been fixed. One problem is the handle itself, which is prone to breakwhich will result in a dropped scope. LeCroy replaced it with the improved handle of the Xi-A which is black. In addition, the standard cooling fans were insufficient to prevent premature PSU failures and front end connector failure through overheating/thermal stress. I'd recommend to get some uprated fans with higher airflow for the scope (there are three main fans, one left for the PSU, one right and one on the acquisition board located over the ADC hybrids.
And since he'll have his scope open, I'd strongly recommend to replace the awful Celeron M CPU with a Pentium-M Dothan with 2MB cache, and upgrade the RAM to 1GB, which will provide a nice performance boost.
The following users thanked this post: JPortici, pilotchup, Kirkhaan
Offline tautech
« Reply #6 on: September 03, 2018, 08:50:01 am »
If that was the big W, well yes we miss his wide knowledge of LeCroy equipment.  :(
Offline Mr Nutts
« Reply #7 on: September 03, 2018, 09:22:59 am »
Yes it's the big W  :).
I believe by now I must be chewing his ear off with my many questions but still he's answered all of them, and in a way even I understand  ;) I already learned so much from his messages and what he wrote in this and "the other" forum, lol  :)
Offline tautech
« Reply #8 on: September 03, 2018, 09:28:04 am »
No need to be shy about where Wuerstchenhund is:
https://forum.allaboutcircuits.com/
« Reply #9 on: September 09, 2018, 03:09:02 pm »
I've replaced the BIOS backup battery and the scope works fine again!
Many thanks to Mr Nutts and Wuerstchenhund for their advice!  ;D ;D
Online 2N3055
  • Country: hr
« Reply #10 on: September 09, 2018, 10:03:17 pm »
Glad you made it work again.
I have a question: how loud (acoustically) the scope is?
Thanks!
« Reply #11 on: September 10, 2018, 06:44:30 am »
I don’t have a SPL meter here. So an accurate answer I cannot provide.
At start-up the fan’s go to full speed for a couple of seconds.
That sounds really like it is lifting up...  8)
But after that they slow down and are (at least for me) not disturbing at all.
Online 2N3055
  • Country: hr
« Reply #12 on: September 10, 2018, 06:52:21 am »
Thanks a lot,  exact dB not needed, just user experience.
Best regards,
Sinisa
« Reply #13 on: September 10, 2018, 07:44:29 am »
I noticed quite some accumulated dust inside, obstructing good air flow through the heatsinks.
I guess this is one of the main reasons for the “overheating” of these scopes that you sometimes reed about.
Offline darkstar49
« Reply #14 on: September 10, 2018, 09:17:59 pm »
It’s more than just dust... the fans are underdimensioned...
In a normally warm room,it will be mostly Ok, but if you have higher temps and/or bad ventilation, think of replacing them !
Offline Mr Nutts
« Reply #15 on: September 11, 2018, 08:46:08 am »
It appears the best thing to do is to replace the fans in any case, even if you're working in a moderate climate ;)
Offline pilotchup
« Reply #16 on: September 23, 2018, 08:48:15 am »
I know the OP has is problem solved thanks to W and the others helping greatly in this thread, but is there a way to get a "service manual" still for this scope?
I just bought one on eBay, and it is the "blue" handle type - older April 2006 version 64Xi. I haven't been able to test it yet but man this thing is chock full of dust.
Would love to know what Lecroy did to "service" them to where they have the black handle if anyone has any info on that.
Really, an resources or documentation would be super helpful. I found stuff like operators manual and some forum posts for specific problems, but nothing too much.
Thanks for anyone's help on this!
« Reply #17 on: September 27, 2018, 05:26:31 am »
The last service manual that seems to be available publicly is from the WaveRunner 6000A series.
From Xi series onward I have not seen them popping up anywhere...
Offline pilotchup
« Reply #18 on: October 07, 2018, 04:24:33 am »
Yeah, it seems to be confirmed from another owner's group.. the service manual for the WRXi is not available anywhere. Real shame!  :'(
Offline Kjelt
« Reply #19 on: March 12, 2023, 09:37:15 am »
Sorry to bring an old topic back alive but I think keeping all the info bundled is better than 30 small topics.
My questions about the 44Xi since I will replace the hdd with an PATA ssd (Transcend TS32GPSD330)
- is there somewhere a teardown post / video with steps how to disassemble this scope
- if I look at the picture above it does not look like the cpu can be replaced/upgraded or can it ? Eg has it a socket?
- what fans are recommended as replacement?
Thanks.
Offline perdrix
« Reply #20 on: March 13, 2023, 05:31:01 pm »
LeCroy sent me the Xi service manual on request but asked me *NOT* to distribute it.
Apparently someone in LeCroy thinks that they should try to keep track of the people who have it.
D.
« Last Edit: March 13, 2023, 05:32:56 pm by perdrix »
Offline Kjelt
« Reply #21 on: March 13, 2023, 07:12:20 pm »
Can you sent me a pm with the emailaddress where you succesfully contacted LeCroy then I will also ask them.  :)
Offline perdrix
« Reply #22 on: March 15, 2023, 02:08:22 pm »
support@teledynecroy.com
Unfortunately what they sent doesn't have schematics.
Cheers David
The following users thanked this post: Kjelt
Offline Kjelt
« Reply #23 on: March 16, 2023, 08:40:54 am »
The above email address is in the mean time out of order, I tried the new one for Europe:
lecroy.service.europe@teledyne.com
Offline Kjelt
« Reply #24 on: March 16, 2023, 10:28:32 am »
And denied by a third company that there are service manuals.
I guess you got really lucky back in the day when it was still LeCroy.
Actually a reason not to buy any second hand LeCroy with this kind of "lack of service".
There are no existing service manuals available for disassembling Teledyne oscilloscopes as this manufacturer preferably wants you to send the scope to them for any service or repair.
