I picked up some paint to redo my cases today. It's Rustoleum "Lagoon".
Here's a test spot with normal house lighting:
Now under white LED lighting:
It doesn't look anywhere near that blue in person. The other option was Krylon's "Jade" but I thought it would be too green.
Personally, I kind of dig the color; sets it apart from Tektronix gear, so I might go with it, even for the units I resell.
In other news, that new OpAmp will be here today, so I need to get the front back on the 2020B!
I took it off to really clean and test the switches and pots. I tested the switch bank, with a four wire lead hooked up, I went through the entire range from least significant decade up. With the switches set to 9.99[10] I got 10.00001k on my 6.5 digit HP '57A. Not a signal damn resistor was out. After 35 years!
I also took the current pot/switch and vernier apart, scrubbed them out good, relubed with WD-40's White Lithium Grease (that stuff is amazing; you spray it and it "drys" into a normal film of lithium grease), then used DeOXIT Shield to protect the wiper contacts.
The switch portion of the current pot got sprayed with WD-40 Silicone Lubricant and the contacts cleaned and shielded with DeOXIT.
What do you guys think for the moving parts of the switch banks, lithium grease or silicone lubricant?
Sent from my Smartphone
