Author Topic: POWER DESIGNS PRECISION POWER SUPPLIES  (Read 345281 times)
0 Members and 12 Guests are viewing this topic.
Offline GK
Re: POWER DESIGNS PRECISION POWER SUPPLIES
« Reply #225 on: June 27, 2013, 11:44:14 am »
Looking at those photos posted by SLJ I just assumed remote sensing wasn't a feature as there are no appropriate/bridgeable binding posts on the front panel besides the output binding posts for the purpose.
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #226 on: June 27, 2013, 11:55:19 am »
No problem, your forgiven, as long as you have a glass of coolaid on us :scared: :-DD
Offline don.r
« Reply #227 on: June 27, 2013, 02:14:23 pm »
Most of these older supplies put them on a barrier strip on the back.
Offline JBeale
« Reply #228 on: June 27, 2013, 09:39:54 pm »
I am checking out an old Power Designs Model 2005A which has been sitting in a garage for a long time. I don't have anything to check it with better than a Keithley 196 DMM (from ebay, and 4 years out of calibration).  The 2005A seems to mostly work.  After warmup, the OVEN lamp flickers sometimes as it probably should, and the indicated voltage output drifts less than 20 ppm in one day.  However, pressing on or slightly jiggling any of the four rotary voltage selectors shows some jumpiness in the output, so clearly there are dirty contacts. I haven't taken it apart yet. Are these contacts copper, silver, gold, something else? Is a spray with contact cleaner likely to help, or will a full disassembly and/or replacement be the only cure?  I have seen Caig DeoxIT recommended, but they seem to sell many different varieties for different contact metals and situations.
Update: ironically, *as I was writing this post* the Keithley's LED display blinked out (it had been working without issue for months). The internal analog +/- 15V power rails are still ok... anyway, a problem for another post.
« Last Edit: June 27, 2013, 10:04:45 pm by JBeale »
Offline robrenz
« Reply #229 on: June 27, 2013, 10:21:41 pm »
I suggest compressed air first if you have it to remove all dust that will blow off. Then a thourough wash with a general electronic cleaner to get the general gunk off the switch assemblies and the detents.  The detents will probably have caked old grease in the ball pockets. Then apply deoxit D100L to all the contact fingers and thoroughly cycle the switches. Re lube all the places where the switch shaft engages other parts and grease the detent assemblies. I personally like wash the D100L off and then lubricate with Deoxit G100L.
some links from this thread here
Offline uoficowboy
« Reply #230 on: June 27, 2013, 11:06:33 pm »
OK - since this is the Power Designs mecca thread...
I have a TW5005W. Lovely supply. Mine needed a couple electrolytics replaced when I received it but has otherwise aged very gracefully.
Only thing is that I am kind of a stickler for cleanliness. I removed all the stickers from it. Got rid of all the adhesive gunk from beneath the stickers. But unfortunately, some of the stickers had been on there... a long time. So the metal front panel (Aluminum I think?), has yellowed in all places except where the stickers were (oh, and also beneath the knobs). Beneath the stickers and knobs, the color is fine. I noticed a bit of acetone gets rid of the yellowing, but I'm worried that the acetone will remove all the silkscreened labels so I have not pursued that.
Any suggestions for getting rid of the discoloration? Any idea what it is?
Sorry to not talk about their precision supplies. I have one of those too - a 5020 - but it hasn't needed any work and also still looks pretty.
Offline robrenz
« Reply #231 on: June 28, 2013, 12:18:29 am »
Have you tried magic sponges?
Offline uoficowboy
« Reply #232 on: June 28, 2013, 12:25:01 am »
No but I don't trust those things - they're pretty much just normal sponges mixed with sand and chemicals. I think they'd take off the silkscreen as well as the yellowing.
Offline don.r
« Reply #233 on: June 28, 2013, 12:30:53 am »
Usually, they are made from melamine foam.
It is also the component of Magic Eraser and similar cleaning products.
As long as the surface you are cleaning is not softer than melamine, it will not scratch. Silkscreen may be an issue.
« Last Edit: June 28, 2013, 12:43:14 am by don.r »
Offline dave3533
« Reply #234 on: July 01, 2013, 06:47:12 am »
When you guys are cleaning the decade voltage knobs, are you removing them from the supply or just cleaning them in place?  If you are removing them, how difficult is it?
Thanks!
 8)
Offline robrenz
« Reply #235 on: July 01, 2013, 11:55:48 am »
I cleaned mine in place.
Offline don.r
« Reply #236 on: July 01, 2013, 03:45:50 pm »
In place. QTip and IPA.
Offline c4757p
  • adieu
« Reply #237 on: July 01, 2013, 03:47:23 pm »
Don't even think about it.
Offline dave3533
« Reply #238 on: July 02, 2013, 02:32:17 am »
:-+ I figured that was probably the case  ;D
I purchased this 5020 on ebay and it was in poor shape initially.  The circuit board visible from the top of the unit was coated in black dust.  I've used denatured alcohol to clean most of the grime out (think I have about 3 hours of cleaning into the top circuit board  :o).
I still haven't figured out the best way to clean the front aluminum, any suggestions?
I also noticed that the circled component below seems to have a "loose" top, ie it will wiggle and slightly rotate.  I've essentially left it alone for now to prevent damage, as the supply seems to work well regardless.  I'll look up the component after I finish cleaning.
Once I finish cleaning it I'll put it through its paces :)
« Last Edit: July 02, 2013, 02:37:23 am by dave3533 »
Offline c4757p
  • adieu
« Reply #239 on: July 02, 2013, 02:38:44 am »
That's no inductor, that's the voltage reference (LM399 is a classic precision oven-stabilized reference). It's supposed to be loose like that.
It sure has evolved from the massive red can oven in the earlier models! And woo! PCB! :P Mine's point-to-point on turrets stuck in a piece of copperless FR4-ish material.
« Last Edit: July 02, 2013, 02:40:24 am by c4757p »
Offline SLJ
    • Steve's Antique Technology
« Reply #240 on: July 02, 2013, 03:42:49 am »
I cleaned the front of mine with rubbing alcohol.  Put it on with a swab and let it soak into the stickers and then used a wide plastic alignment tool to scrape most of the paper and glue off.  then used more and wiping with a paper towel until they were clean.  Did not seem to bother the silk screened markings.
Offline ddavidebor
    • Smartbox AT
« Reply #241 on: July 02, 2013, 05:20:17 am »
Naaa alcool don't work very well.
You should use a degreaser (for the kitchen, NOT a solvent based ones)
Il you want it like new you must remove everything from the front panel and clean it separately.
Next, you should use alcool to remove all the trace of the degreaser especially from glass surface.
Here i use chanteclair, is a  degrasser. It's so good that i buy it in 5L bottle.
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
Offline ElektroQuark
    • ElektroQuark
« Reply #242 on: July 02, 2013, 08:40:25 am »
Some degreasers have NaOH as main active ingredient. NaOH eats aluminium, so beware, they can damage the panel finish.
Offline robrenz
« Reply #243 on: July 02, 2013, 11:25:32 am »
Why would you contradict a forum member that has cleaned more equipment than you have even seen?  :-//
Offline SLJ
« Reply #244 on: July 02, 2013, 12:07:31 pm »
Before/After
Remember to let the alcohol sit on the paper stickers to soften them.  Still watch out for any screened printing. It did OK with both my PD supplies but depending on manufacturer it could still do damage to the print.  Again, something soft plastic helps scrape off the goop without scratching the panel.
Actually sticker and label glue is not usually as bad as smoke residue.  Some of the early test equipment is so bad the panels have to be removed and soaked.  Bakelite panels and cases can be cleaned and polished using mag wheel cleaner you get at an auto supply but it removes any printing.  I would not use it on brushed metal panels though.
Offline robrenz
« Reply #245 on: July 02, 2013, 12:21:09 pm »
I have found Toluene and Xylene especially effective on sticker goo.  "Goof off" and "Goo gone" are two that are readily available in the US with same or similar active ingredients. These will usualy totaly liquify the adhesives right through the stickers if the stickers are paper/pourous. If the stickers are non pourous then you need to keep a "wet front" on one edge as you gradualy peel the sticker up.  As with most things the magic sponges will enhance the cleaning action.
Offline nukie
« Reply #246 on: July 02, 2013, 11:30:47 pm »
LM399 in a power supply!!! 8)
Offline uoficowboy
« Reply #247 on: July 03, 2013, 01:23:35 am »
Has anybody tried taking apart the rotary switches? I'd like to clean the contacts on the other right knob on my 5020. They are showing their age a bit...
Offline SLJ
« Reply #248 on: July 03, 2013, 03:13:41 am »
See page 16.
Offline uoficowboy
« Reply #249 on: July 03, 2013, 05:07:15 am »
See page 16.
Nobody seems to have tried, hence my question.
On a side note - anybody have a *clean* scan of the schematics for the 2020 or 5020? The only ones out there seem to be pretty much unreadable.
