Author Topic: Best Bench top power supply?  (Read 3692 times)
Offline thelearnerTopic starter
  • Country: in
« on: November 02, 2020, 07:06:13 am »
Hello,
I am looking for a benchtop power supply for my lab under $250. Any suggestions?
TIA
Offline Trader
Re: Best Bench top power supply?
« Reply #1 on: November 02, 2020, 08:51:24 am »
Tekpower TP3005T Variable Linear DC Power Supply, 0 - 30V @ 0 - 5A
Offline masterx81
« Reply #2 on: November 02, 2020, 10:00:19 am »
Korad ka3305d or ka3305p. Mine works quite well. And 3 channels are useful
Online radiolistener
  • Country: ua
« Reply #3 on: November 03, 2020, 11:15:56 am »
KORAD KA3005D has capacitor on the output, so it has some issues with current stabilization. But this is really best middle class PSU.  :-+
Offline masterx81
« Reply #4 on: November 03, 2020, 11:28:37 am »
I think that most of the psu in this price range has some capacitance at the output. Need only to be careful to always use the turn on/off function instead of live connecting the things. There can be some problems also on repentine current draw changes
Offline TurboTom
« Reply #5 on: November 03, 2020, 11:35:20 am »
OP should first specify required number of channels, output voltage (range) and power, and if the acceptable amount of output noise will permit a switcher. After that, suggestions make sense and could possibly lead in a different direction...
Offline S. Petrukhin
  • Country: ru
« Reply #6 on: November 03, 2020, 10:15:12 pm »
And sorry for my English.
Offline Purduephotog
« Reply #7 on: November 08, 2020, 03:14:18 am »
Anything high voltage- aka, 70V (ish?)
« Reply #8 on: November 08, 2020, 03:37:03 am »
Most multichannel PSU's can be seriesed to give at least 60V and some can go into series mode with just a press of a button.
Offline Fungus
« Reply #9 on: November 08, 2020, 03:52:30 am »
Hello,
I suggest posting some requirements, not just a price.
Offline ResistorRob
« Reply #10 on: November 08, 2020, 05:27:52 am »
I like this better than the Korad, but I tend to be an odd duck  ;D
SIGLENT SPD1000X Series Programmable DC Power Supply
Only single channel, but very precise and ultra low ripple.
Available in 2 varieties:
  • SPD1168X: 16 V / 8 A,total power up to 128 W
  • SPD1305X: 30 V / 5 A,total power up to 150 W
Has 5 digit Voltage, 4 digit Current Display, Minimum Resolution: 1 mV/1 mA
I think it looks sharp on the bench with it's color LCD display.
I already have a 3 channel boat anchor, so I have my eye on this and other similar products, so thought I would share. It's great if you don't need multiple channels.
For my 10th Birthday I got a Fisher Price oscilloscope!
The following users thanked this post: ogden
Offline BravoV
  • +++ ATH1
« Reply #11 on: November 08, 2020, 06:11:28 am »
Hello,
The OP is from India, there, any "high tech" even such as bench power supply, is considered an expensive item.
  • Country: ua
« Reply #12 on: November 08, 2020, 06:44:31 am »
looks very good, but this PSU is twice more expensive than KORAD KA3005D
« Last Edit: November 08, 2020, 06:46:50 am by radiolistener »
Offline BravoV
  • +++ ATH1
« Reply #13 on: November 08, 2020, 09:33:25 am »
What you guys are suggesting, reduce the price tag to about 33% to 50%, as India will put quite a hefty import tax for such merchandise, guess where did I learn that.  ::)
So, for $250 budget, if imported, then the realistic price that we're going to suggest maybe about $75 to $100 price level of merchandise.  :P
