Author Topic: DM3058 Run/Hold  (Read 525 times)
Offline bofulTopic starter
DM3058 Run/Hold
« on: April 11, 2022, 09:40:54 am »
Greetings..
Rigol DM3058
I have been trying to use the RUN/HOLD option without any luck.   Looking at the manuals description and instructions, should be similar to Flukes 'Touch Hold' function.
Have had no luck having any measured value remaining on the display once test leads are removed.
Just feels like operator error :-)
Any suggestions on how this function should work,  sure seem like it would be simple.
Thanks
Offline hexreader
Re: DM3058 Run/Hold
« Reply #1 on: April 11, 2022, 01:14:28 pm »
The "single" button probably does what you want.
Offline 2N3055
  • Country: hr
Re: DM3058 Run/Hold
« Reply #2 on: April 11, 2022, 02:34:52 pm »
Read the manual. Keyword here is trigger.
