Hi ci11,
thanks a lot for the list! Very helpful and very much appreciated!
The QuantAsylum QA401 You mentioned I already had an eye on and (not only after what You wrote) I indeed have to contemplate some more if this would not be a (better) option for me.
Lastly this is the only one of the dedicated analyzers for audio in the price bracket of what I could still justify to spend.
Regarding the EMU, I`m not so concerned about software and installation. As mentioned, I already have a dedicated DELL laptop with WinXP and Win7 for it.
So no need to hassle with Win10 installation, band-aids to get it running and/or worrying about (Win) udpates to keep it up running.
The EMU with Win7 should not be a problem, even less so with WinXP.
However, the EMU PatchMix software is indeed very confusing to me but I have not yet made any serious efforts to understand how it works.
I`m convinced, once necessary and when I really get into it, I will handle it.
What I like about the 1616m is that I could use it not only for electrical measurements but with various software (ARTA for example) also for speaker measurements.
I do have a dedicated PC based speaker measurement system though - but to use it, I have to carry around the clunky, heavy, loud 19" PC case with an even older ISA mainboard in it.
With a 12V to 48V power-supply + battery for the EMU and the laptop also on battery, the system could be running even completely independent from mains voltage (thinking car audio or outdoor speaker measurements).
What I`m also not much concerned about is the heat issue. I`m convinced, once recapped with quality caps, the EMU would last a long time, despite the heat (as I`m already of what could be called somewhat "advanced" age, it might even outlive me....).
Especially as I intend to use it for measurement purposes exclusively. It would be comparatively short times it will be actually in use.
Moreover the heat issue could be solved with some more case vents or maybe even a small fan.
I do not worry about "verified instrumentation purposes". This is just for occasional hobby usage.
What is indeed the biggest drawback with a soundcard are missing attenuators and to some extend a low-distortion generator (but I have an old Krohn-Hite which I think would be good enough) and finally a notch-filter.
As always back at the very basic two options: soundcard + DIY periphery or spending the bucks on something like the QuantAsylum (+ accessories). Hmmm...
There are worse things in live than this kind of "luxury" decisions..
