Hello 1audio,
I have read Your posts over at diyaudio about the EMU 1616 and took quite a few notes.
Thanks for that and thanks for Your reply!
Good to know, to have in mind and to take extra care about what You mentioned regarding the pin headers!
Already yesterday I was almost about to dismantle the EMU - but wimped out...
Yes, judged by the cosmetic appearance I think my EMU 1616 has seen little use but that does not mean much IMO. Could be it was just handled gently.
And only a few days ago I had a failure with another oldie but goodie which I know was hardly used. A Terratec Phase X24 FW I still use occasionally.
Although it is really old as well, I still like it a lot not only for it`s headamp and use it with my desktop PC (win7).
However, have not used the Phase X24 a couple of years. Switched it on recently, it came on but did not work properly anymore (sound just stopped after a few minutes).
Took it apart and the first thing I noticed was one cap in the power-supply already bulging. That was definitely not the case before, because when I got it, I opened it up, of course.
That means the cap has gone bad meanwhile, even without using the gear. While I was at it, measured a few other caps. Some more dead or at least highly suspicious.
IMO does not make much sense to change just the already obviously bad ones.
Same as with the EMU, the only ones which could be kept in are the coupling caps, maybe, I believe.
I am aware that changing the caps is a lot of work and it won`t be easy. More so as I don`t have a vacuum desoldering station.
Would have to do it the "old way" with desoldering braid and/or manual desoldering pump. Maybe it is time to invest in a proper desoldering tool eventually...
From what I have read, changing anything else besides the caps does not bring noticeable improvement, if at all. So I will leave it at that.
>> Cardbus. Not long ago I bought a second Dell Latitude E6500 notebook just for the EMU and older software I still want to use.
My first DELL I bought second hand >>10 years ago. Still in use and still going strong (for what I use it anyway). I love these DELLs.
Today they are dirt cheap and go for only a couple of bucks. The EMU 1616m (+ Cardbus + 2 PCI cards + 2 Power supplies) + the DELL did cost me only slightly >100€ together.
Not bad for something what could potentially almost rival an AP for audio stuff (minus of course the attenuators etc., etc. the AP has to offer).
Installed dual-boot WinXP and Win7 on the DELL and deactivated all the stuff I don`t need. So no need for me to hassle around with Win10 (I really hate anything >Win7).
I still need a lot of TRS cables for the 1616m though, which will cost me quite somewhat, even when soldering the cables myself.
My 1616m came with 2 MEAN-WELL 18W/48V power-supplies. Both get hot. Measured the power consumption: 14-15W. So just shy of the rated 18W.
Seems EMU cheaped out not only on caps but on the power-supply as well.
Or maybe this is a sign that already something in the EMU Microdock does not work as it should (albeit it seems to work okay, as far as I can tell)?
As I don`t like things running so hot, I will replace the Mean-Well with something more powerful and somewhat better specs wise, if possible.
Maybe a PS with better specs (output ripple) can have an impact on overall quality as well. Maybe not.
So, if nobody comes up for the EMU 1616m with something similar as on the attached picture (or a list of caps, so I can order parts, without having to disassemble the EMU first)
I have done (precautionary) for the Phase X24-FW years ago, (unfortunately) I have to do it myself.....
