Author Topic: Looking for Agilent DMM Connectivity Utility Software  (Read 13174 times)
Online KosmicTopic starter
« on: October 10, 2018, 05:12:54 pm »
Hello,
I got a Agilent 34401a and I’m looking for a simple software to log data for more than a hour. My understanding is that Agilent DMM Connectivity Utility Software was free at some point but now it’s nowhere to be found.
If anybody has a copy of the software, I would be really interested.
Thanks!
Edit: D/L link https://1drv.ms/u/s!AjGAejk8r_C1j9h1NnX-l3Nxfaqq4w?e=u5SeBf
« Last Edit: November 30, 2021, 02:27:38 am by Kosmic »
The following users thanked this post: coromonadalix, hoangviet
Offline Carrington
Re: Looking for Agilent DMM Connectivity Utility Software
« Reply #1 on: October 10, 2018, 05:43:47 pm »
I have a copy of the "Agilent DMM Connectivity Utility v1.0.2.0".
I'm not sure if it was the latest version, maybe someone has a newer version (or a better alternative), anyway:
https://filebin.net/1a24py8nbb285cje
« Last Edit: November 12, 2018, 07:23:31 pm by Carrington »
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
The following users thanked this post: coromonadalix, Mr. Scram, Kosmic
Offline MosherIV
« Reply #2 on: October 10, 2018, 09:58:12 pm »
I used an old HP branded bench dmm.
I had to download the usb drivers for windows. They were really complicated, they were usb measurement standard drivers.
Anyway, part of the driver package was a plugin for ms excel which allowd control and logging from the bench dmm straight into excel.
Try looking at the usb drivers from Keysight.
« Reply #3 on: October 10, 2018, 11:24:51 pm »
https://filebin.net/8nof4slqaxr4w7oe
Got the file. Much appreciated!
Thanks,
« Reply #4 on: October 10, 2018, 11:26:04 pm »
Yes I found that but I was looking for something a bit more visual  :)
Also I currently don't have office installed on my computer.
Offline Astrodev
« Reply #5 on: October 10, 2018, 11:35:57 pm »
Doesn't Command Expert allow you to do this from within Excel or using the stand alone app.
Offline canada13records
« Reply #6 on: November 12, 2018, 05:27:53 am »
Would you please share the file again? Just got a 34401a on Friday, but your link says it expired 1 day ago.
Offline maukka
« Reply #7 on: November 12, 2018, 03:55:58 pm »
I got mine here (edit: redirect dead now) and it works perfectly with the 34401A.
« Last Edit: November 12, 2018, 05:55:13 pm by maukka »
« Reply #8 on: November 12, 2018, 04:55:15 pm »
Will put it on a share tonight after work.
« Reply #9 on: November 12, 2018, 04:56:15 pm »
I got mine here and it works perfectly with the 34401A.
I tried to download from that link but the .exe was always corrupted  :-//
Offline maukka
« Reply #10 on: November 12, 2018, 05:54:05 pm »
I suppose that link only redirects to the Keysight website, which doesn't allow the download anymore. Worked a month ago.
Offline Carrington
« Reply #11 on: November 12, 2018, 08:10:47 pm »
New link added, check my previous post.
However, can someone upload it to any other site that offers permanent links without requiring registration to download it?
Thanks.
Space Weather.
Offline Menen
  • Country: ru
« Reply #12 on: April 15, 2019, 08:28:04 am »
The link is again dead. Who can share?
« Reply #13 on: April 16, 2019, 11:23:47 am »
Fixed for now. I need to find a permanent place to put that file.
The following users thanked this post: Menen
Online voltsandjolts
« Reply #14 on: April 16, 2019, 12:26:17 pm »
Can someone please list the the meters that are supported by this application?
Edit:
After installing I still can't see a list of supported meters!
I think it is for bench meters but not handhelds, perhaps?
For instance, it does not support U1272A, but for that you can use "Keysight Handheld Meter Logger Software for PC" which is free (for now).
« Last Edit: April 18, 2019, 03:38:13 pm by voltsandjolts »
Offline Menen
  • Country: ru
« Reply #15 on: April 17, 2019, 05:05:25 pm »
Required for installation "agilent io libraries".
There is a current library at that time?
« Reply #16 on: April 17, 2019, 11:00:14 pm »
I used it with IO Libraries 2018.1. Was working fine.
Offline Menen
  • Country: ru
« Reply #17 on: April 18, 2019, 11:34:18 am »
Thank. Earned the latest version IOLibSuite_18_1_24130.exe.
Offline iMo
  • Country: cv
« Reply #18 on: July 13, 2019, 09:18:04 am »
Thanks for sharing!
Btw, did somebody try to connect the 34401A via a bluetooth module, like
34401a rs232 <---> max232 <---> HC-05 (Rx/Tx/Gnd)
« Last Edit: July 13, 2019, 09:20:46 am by imo »
Offline iMo
  • Country: cv
« Reply #19 on: August 03, 2019, 02:45:14 pm »
Ok, so I've tried harder and it works.. (HP34401A)..
2 transistors RS232 to 3.3V signalling, LE33 voltage regulator and HC-05.
Powered from the 9pin RS232 rear connector, no other power source required, do not ask how it is done :)
Works under Agilent DMM connectivity at 1, 10, 100PLC without handshaking, sometimes the connectivity is lost upon initiation. Needs to be investigated..
Offline hakko
« Reply #20 on: September 21, 2019, 05:14:34 pm »
Download link is down. Can someone re-upload it?
« Reply #21 on: September 21, 2019, 05:23:22 pm »
Try again.
The following users thanked this post: hakko
Online coromonadalix
« Reply #22 on: September 22, 2019, 01:58:15 am »
The io libraries  18.1.24715              251megs
https://www.keysight.com/main/software.jspx?cc=CA&lc=eng&ckey=2175637&nid=-33330.977662&id=2175637
You have to rgister at keysight if i recal correctly  or put anything in the required fields ??
The following users thanked this post: Gandalf_Sr
Offline Gandalf_Sr
« Reply #23 on: September 24, 2019, 12:08:41 am »
I successfully installed this on my Windows 10, 64 bit laptop but will it work with more modern Keysight meters like the 34461a?  It looks very like the Keysight Handheld Meter Logger Software but that only supports...
U1210, U1230, U1240B, U1240C, U1250, U1270, U1280, U1450A/60A Series and U1115A
If at first you don't succeed, get a bigger hammer
Offline apollo2mond
« Reply #24 on: December 29, 2019, 01:03:09 pm »
Hi, please could someone again make available the DMM Connectivity Utility sw?!
Many thanks in advance, a2m!
