Author Topic: Looking for a PC based digitizer  (Read 997 times)
Offline sdoubleTopic starter
« on: April 05, 2018, 11:31:58 am »
Hi all,
I'm looking for a high dynamics (14+ bits, SNR >60 dB , SFDR >70dB) digitizer using the PCIe posrt of a desktop PC.
Moderate bandwidth  : -50 MHz analog, 100 MS/s if possible.
4 channels would be great, I could cope with only 2.
SMA inputs at best. 50 ohms input impedance.
Cost sensitive application.
If you know some supplier, don't hesitate to post. ;D
Cheers
Ju
Offline simone.pignatti
Technical Support
Technical Support
Re: Looking for a PC based digitizer
« Reply #3 on: April 05, 2018, 10:46:46 pm »
thanks.
I'm actually after a PCIe board.
Moreover i do need advanced triggering option.
I need to filter (trapezoidal shaping) the signal and trigger on the shapped output.
