It is hard to find any reviews online about the GDS-series scope.
but many videos on youtube (with fraking computer voice), i know that's not real reviews but at least something
From a quick glance at the specs:
- Only 200MHz bandwidth limit on the 350MHz model? Usually 20MHz is also offered.
datasheet and user manual is a bit better than the info on the website, it does have such bw selectors:
150MHz model: Full, 20MHz
250MHz model: Full, 20MHz, 100MHz
350MHz model: Full, 20MHz, 100MHz, 200MHz
- No mention of waveform update rate
right, there is even nice compare to WaveJet, DPO2000 and TDS3000
http://www.testequipmentconnection.com/specs/Instek_GDS-3354.PDFbut no single word about wfrm/s, even not in "VPO Technology Introduction" which is actually talking about dead time
http://www.gwinstek.com/vpo/This mean it would be not better than on WaveJet / DPO2000 or TDS3000
Tek DPO2000 - 5k wfms/s
Tek DPO2000 - 3.6k wfms/s
LeCroy WaveJet - 3.6k wfms/s
so let's gues, somethign about 2k - 2.5k wfrm/s
There is "GW Instek GDS-3000 vs. Tek TDS3000" video on youtube, if you watch carefully the TDS is updating faster the
same video signal ...
The 5GSs on 4ch model are interleaved, giving you 1.25 in 4 and 3 ch mode, 2.5 in 2ch and 5GSs in 1ch mode
which is "ok" (at least in one chan mode 5Gss there), but it is not good on 2ch DSO because there is only 1.25GSs or 2.5GSs
available.
There is only 1kHz for probe compensation, hmm.
What i like, without testing are
- 50, 75 and 1M ohm selectable input impendanze (but with 75Ohm bw is limited to 150MHz!)
- colored persistency display
- the multi window display (like Yokogawa)
- HDTV triggers
- TTL/ECL trigger presets
- event delayed trigger (waits for 1 to 65535 events to trigger)
Nothing particularly exciting apart from the bandwidth in my opinion, doesn't appear to be in the same league as the Agilent 2000X series.
fully agree
