Rough requirements
- Bench DMM
- At least 5½ digits
- Physical depth should not be above 35 cm so used 34401A and similar are a bit too big from what I've seen
- €500-1000 preferably but could go higher
Other nice to have
- PC/LAN connectivity for remote control
- Trend chart is nice I've heard
I've tried to do research on units like the Siglent SDM3055, SDM4055A or Hantek HDM3055 but I don't see a lot of reviews or teardowns so it feels difficult to get a sense of their quality and performance after long term use. Some say they're great while others say they get DOAs or have found some annoying behaviour.
Any obvious choices for the budget?
Any features I should really look for that I might not know about or have listed?
In your budget, you could get a nice 6.5 digit meter. I own the SDM3065X, Keithley DAQ6510 (same analog board as DMM6500), and Keysight 34465A. They're all good, but my preference in order is Keithley, Siglent, Keysight.
The Keysight is nice, but the continuity options are lacking compared to the other models (despite being very fast), and it hasn't had a firmware update in years, despite the fact that it could certainly benefit from one.
IME, the Siglent SDM3065X is the best bang for the buck model. It needs some burn in time for stability, but I have not had any issues.
In your budget, you should be able to afford the newer SDM4065A (which seems to maybe not need the burn in time?). If you're not in a hurry, you can wait a while and the firmware will get developed farther before your purchase it. Or if you want to be an early adopter, you might have to deal with some hiccups before it gets fixed. This is speculation- I have no reason to believe there will be issues other than that there usually is something people find when a new product is released from any brand.
IME, Keithley is the best, both from the perspective of the hardware itself, and their support. You can find a used DMM from them in your budget. The DMM6500/DAQ6510 have the most advanced graphing and data available from any of these meters.
Keithley's support thus far, has been incomparable. Siglent support has generally been good to me, but still comes in second behind Keithley. Keysight support was okay at best so far, but certainly nothing to brag about.
Your depth requirement might not fit the Keithleys, but you can do what I did (if you have the space) and design support for them to hang off the back of the bench, rather than take up extra space on the bench. Both the Siglent and Keysight should fit your space requirements otherwise.
Thanks,
Josh
