Author Topic: Looking for a budget laboratory power supply from European manufacturer  (Read 15162 times)
Offline midixTopic starter
Hi all.
I have seen many power supply recommendations but they are mostly around the USA or Australian, or unknown Chinese brands.
I live in Europe (Latvia, to be more accurate) and I would like to buy a budget (under 150 EUR) power supply for my DIY projects. I'm looking at minimal range of 0-30V 0-5A models. Intended use - various small projects, mostly Raspberry, Beaglebone kind. But also might have some audio equipment or small motors related. So I'm not exactly sure if switching power supply would be able to deal with it?
I know that I could get one from China for really cheap, but I'd like to have at least some minimal warranty.
So, I looked around in Amazon.de  and some local shops. Many products from unfamiliar brands (Levelpro, ECO-WORTHY) look like rebranded copies of the same model (at least from outside). If it is a good quality copy of a well known model, then I could go with it, but I can't tell from the looks of it.
One of more-less reliable European manufacturers known to me is Velleman, I already have a soldering station and grinding tool (a.k.a. poor man's Dremel) and they seem to be OK. They have a bunch of lab power supplies with required voltage / current range:
http://www.velleman.eu/products/list/?id=341733&page=2
and these also seem like the same "copy-cats" as Chinese ones, so I'm still in doubt, what's inside of them. Also they do not specify which ones are linear (although for some of them it is specified that they are switching, but I'm not sure if all the others are linear) - what parameter in the specification should I look at to clearly see if it's linear or not? Is it ripple voltage and what should it be to make the distinction clear?
If you have experience with European manufacturers (of course, I know that they are made in China, but I hope to have at least more or less reliable circuit design and a warranty), then I'd be grateful for any suggestions.
Online nctnico
Re: Looking for a budget laboratory power supply from European manufacturer
« Reply #1 on: August 25, 2016, 03:10:28 pm »
Can you order from Conrad? They have a bunch of power supplies as well and with some pushing around and cursing their customer support is OK.
Offline robert_
« Reply #2 on: August 25, 2016, 03:44:10 pm »
Just Voltcraft is as far away from european manufacture as you can go. Low quality chinese made instruments with pretty poor performance (like, 1A load step with the output set to 5V results in a dip to 0V for >1ms on a VLP2403).
Even Statron isnt as poor as that with their power supplies thats pretty much still based on 1980s east german technology.
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #3 on: August 25, 2016, 03:48:20 pm »
Well, there is still Hameg, now sold as R&S Value Line, i.e.:
https://www.rohde-schwarz.com/uk/product/hmc804x-productstartpage_63493-61542.html
Hameg gear is made in CZ, so it's actually European made.
You could of course also go for a 2nd hand R&S power supply, which would be made in Germany.
However, while I can certainly understand your caution re. Chinese brands, I don't understand what the problem is with US made gear.
Offline zapta
« Reply #4 on: August 25, 2016, 03:55:18 pm »
For warranty you need a decent European vendor, not necessarily a manufacturer.
Farnell has for example the Temna line with products like this:
http://uk.farnell.com/tenma/72-2540/power-supply-1ch-30v-5a-prog/dp/2445412
Offline wraper
  • Country: lv
« Reply #5 on: August 25, 2016, 04:08:29 pm »
Velleman mostly rebrands Chinese crap.
Offline wraper
  • Country: lv
« Reply #6 on: August 25, 2016, 04:16:57 pm »
If you want something really european, end don't cost an arm and leg, then Thurlby Thandar is your only choice, I guess http://www.aimtti.com/, they are made in UK.
As of cheap PSUs, Mastech would be the the cheapest what I would consider passable for buying if was out of money.
Offline wraper
  • Country: lv
« Reply #7 on: August 25, 2016, 04:20:26 pm »
Have you checked the price of that "value line"?
« Reply #8 on: August 25, 2016, 04:37:07 pm »
Yes, but at the end of the day you get what you pay for, and if it has to come from Europe then there isn't exactly much choice.
Personally, I'm quite happy with my 2nd hand Agilent E3631A plus 3yr repair agreement  ;)
« Reply #9 on: August 25, 2016, 06:05:51 pm »
Thanks a lot for mentioning so many options, I'll definitely explore them.
Actually, I have nothing against the USA models, but it is somewhat hard to find local distributors (to keep manufacturer's warranty) and buying directly from the USA adds noticeable costs, therefore I consider European options first.
Online nctnico
« Reply #10 on: August 25, 2016, 06:12:46 pm »
Still why do you want to buy new? The older HP/Agilent power supplies are very nice (I'd recommend one without a fan) and probably better then anything that fits in your budget. For the cheap brands I doubt there is something like manufacturer warranty. Warranty is something between you and the supplier. If a manufacturer provides warranty it is because they want to offer good customer service but they are under no obligation to do that.
Online Hydrawerk
« Reply #11 on: August 25, 2016, 06:22:35 pm »
If you want a PSU made in Europe, you might consider Diametral from Czech Republic. http://www.diametral.cz/ac-dc-zdroje/dc-regulovatelne-zdroje/laboratorni.html
Or Statron from Germany.
http://www.statron.de/?lang=1
I think that Statron is better. But they are very oldschool.
http://www.statron.de/details/170
I doubt there is any MCU inside. Probably no advanced measurement functions.
« Reply #12 on: August 25, 2016, 06:37:34 pm »
Well, at least it is nice to have the warranty from the seller - here in Europe every seller is obliged to provide at least two year warranty, which I won't have when buying from ebay or China or a used item.
I could also look at used options from reputable brands, if I can find one from a trustworthy seller and with reasonable shipping costs.
BTW, just curious, what's the real difference between:
and
http://www.velleman.eu/products/view/?id=417862
Oh, those copied designs... It's impossible to know what the original was, unless you have been in the industry for years...  |O
I think I have seen some Mastech models in local web shops, will take a look; they really seem more reputable than Tenma and Velleman, if I'm not mistaken.
Online Andy Watson
The following users thanked this post: nowlan
Online nctnico
« Reply #16 on: August 25, 2016, 08:28:38 pm »
and
Just that badge !
http://sigrok.org/wiki/Korad_KAxxxxP_series
KAxxxxP seems to be acceptable except older versions which had a serious problem (as seen in some of Dave's videos). And that makes me wonder, which version has been copied - the old or the new - the fixed one  ;D
I just found one more company - PeakTech, seems to be coming from Germany ... and again just a rebranding company, judging from reviews.
So, I guess I'll have to stick with known models from Mastech or Korad, or something from Velleman / Tenma / PeakTech (or maybe even more cryptic names seen in some web shops, like Twintex Pwr, Matrix Pwr, Axiomet Pwr, Levelpro) will do, if only I'm 100% sure about specific model that it is a rebranded clone of something more or less acceptable, and not just a cloned design with completely different crappy internals.
All the other options mentioned - EA ELEKTRO-AUTOMATIK, Diametral, Statron, Hameg (R&S), Voltcraft  - are out of my current budget (some because of high shipping costs) or somewhat difficult to find.
Considering all of this, and after reading some teardowns, currently I'm leaning towards Mastech HY-3005, HY-3005C.
« Last Edit: August 25, 2016, 08:30:46 pm by midix »
Offline setq
« Reply #17 on: August 25, 2016, 08:40:37 pm »
Personally I'd see if you can grab a second hand warrantied TTi supply. The things are bomb proof.
Offline pascal_sweden
  • Country: no
« Reply #18 on: August 25, 2016, 10:26:43 pm »
TTi is Turbly expensive!
Note that Mastech is known to have many copies out there, so I wouldn't go that route either.
Regarding EA Elektro Automatik:
http://uk.farnell.com/ea-elektro-automatik/ea-3050b/power-supply-4ch-300v-5a-adjustable/dp/1437528
This one it says: Country of Origin is China! So it seems they also have it produced in China.
« Last Edit: August 25, 2016, 10:28:34 pm by pascal_sweden »
Offline ebclr
« Reply #19 on: August 25, 2016, 10:30:08 pm »
 :-DD   European manufacturer
Only job available in "Europe manufacturer " is to remove labels and glue new ones, China already dominate the world
Offline setq
« Reply #20 on: August 25, 2016, 10:43:30 pm »
A new one is. Can grab a second hand one off ebay for not much. Warranty? Screw it, you can fix them with your eyes shut, not that I've ever had to (I've owned three so far)
  • Country: no
« Reply #21 on: August 25, 2016, 10:48:18 pm »
I actually misspelled my remark about Thurlby Thandar Instruments.
Thurlby expensive :)
BTW: I don't like their terminals with screws. It's cleaner with just banana jacks.
But of course some people might need the screws. Still then it would be better to have them on the back.
« Reply #22 on: August 26, 2016, 05:34:56 am »
Not sure what you're talking about, there are various national offices and lots of distributors for American big brands like Keysight, Tek, Eaton, Magna-Power etc. In fact, it's easier to find say a Keysight representative than one from R&S.
Also, you can often buy manufacturer warranty (sometimes called a 'repair agreement') for second hand big brand gear, too. My Agilent E3631A plus 3yrs repair agreement did cost me a less than 1/3rd of a new one, while still giving me the same security as to 'warranty'.
Offline TheAmmoniacal
  • Country: no
« Reply #23 on: August 26, 2016, 08:53:35 am »
Apparently the Norwegian brand Mascot still makes laboratory power supplies, like this one: http://www.elfadistrelec.lv/lv/laboratory-power-supply-45-15-vdc-mascot-mascot-719/p/16984306?q=mascot&sort=Price:desc&page=33&origPos=216&origPageSize=50&simi=96.07
No idea if they are manufactured here, the page says Norway is the country of origin?
The one I linked is only 45W though.
  • Country: no
« Reply #24 on: August 26, 2016, 12:19:01 pm »
I was not aware of Mascot :)
Do they have a triple power supply with around 195W? 30V-3A, 30V-3A, 5V-3A?
Maybe this is indeed still made in Norway and comes with "Viking" capacitors that last over time :)
