Author Topic: Component Tester - Good form factor  (Read 766 times)
Offline PerranOakTopic starter
« on: July 18, 2024, 01:38:44 pm »
Can anyone recommend a version of those cheapo component testers in a nice, usable and safe package.
I've had one for a while but it's just a bare circuit board and a dangly battery lead and I keep shorting things with it.  :palm:
Cheers
You can release yourself but the only way to go is down!
RJD
Online KungFuJosh
  • TEAS is real.
Re: Component Tester - Good form factor
« Reply #1 on: July 18, 2024, 01:41:04 pm »
I have the TC1 and the TC3. Both have been fine for component testing. I like the TC3 has extra toys, which is cute. But I really like that it's firmware upgradable. I bought the TC1 in a case super cheap on Amazon years ago. The TC3 is around $50.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline Fungus
« Reply #2 on: July 18, 2024, 02:08:01 pm »
Search for "component tester" on Aliexpress, there's hundreds.
They're all pretty much identical inside.
Offline Fungus
« Reply #3 on: July 18, 2024, 02:13:07 pm »
I just saw FNIRSI makes one with a built-in oscilloscope+sig-gen...
https://www.aliexpress.com/item/1005005298986096.html
The following users thanked this post: egonotto, coromonadalix
Online KungFuJosh
  • TEAS is real.
« Reply #4 on: July 18, 2024, 02:24:03 pm »
That's the TC3 I was referring to. The sig gen and scope are obviously very basic (mostly toys), but I was able to use the scope to test the foil ends of capacitors.
Offline Phil1977
« Reply #5 on: July 18, 2024, 03:20:22 pm »
The FNIRSI-device is 3-4 times more expensive than the T7-transistor tester. The WaveGen and Scope are not even toys. I recommend saving the money.
The T7 is available in a closed housing for around €15, I think it even was in such a "order 3 at once"-offer for €7. It contains a supertiny lipo-pouch battery that is so small that I don't believe it can set anything on fire. But it powers the transistor tester a long time and is easily recharged by a USB-C port.
Offline Fungus
« Reply #6 on: July 18, 2024, 05:09:41 pm »
That's the TC3 I was referring to. The sig gen and scope are obviously very basic (mostly toys), but I was able to use the scope...
I've got one of the standalone $30 'scopes and I've used it many times. It's credit card sized and manages to squeeze in my electronics case with all the other junk.
As they say: The very best 'scope is the one you've actually got with you.
I only wish it was two channels.
(I know there's two-channel toy scopes but they're much bigger...)
Online KungFuJosh
  • TEAS is real.
« Reply #7 on: July 18, 2024, 06:15:39 pm »
I don't call it a toy as a pejorative. I like toys. 😉
Offline Gyro
« Reply #8 on: July 18, 2024, 07:38:11 pm »
Cheers
Which dangly wire tester do you have? If it's the old bog standard T4 then the basic sheet acrylic cases are very functional, even if not particularly stylish. eg. https://www.ebay.co.uk/itm/355753267566
Best Regards, Chris
Offline Kim Christensen
« Reply #9 on: July 18, 2024, 08:20:26 pm »
I like this TC1 version. Nice and compact. Just be aware that most of the new ones being sold don't have a genuine ATmega chip so won't be upgradable.
List of tester clones.
« Last Edit: July 18, 2024, 08:22:08 pm by Kim Christensen »
Online KungFuJosh
  • TEAS is real.
« Reply #10 on: July 18, 2024, 09:39:33 pm »
Here's a comparison of the two I own. The TC3 is 1cm wider than the TC1. I like both, I'd buy either again, but with the change in the chips in the TC1, I'd lean towards the TC3 which is updatable.
Offline Martin72
  • Testfield Technician
« Reply #11 on: July 18, 2024, 09:49:36 pm »
I have this one, which has a pleasant form factor.
However, the focus is on testing semiconductors.
(Kierkegaard)
Online KungFuJosh
  • TEAS is real.
« Reply #12 on: July 18, 2024, 10:31:02 pm »
That's the "TSH06F Integrated Circuit Tester" - it ranges in price from like $30 to $70 for the same thing. I'm gonna buy a cheap one. Or try and control myself? Not sure which will win. 😉
« Last Edit: July 18, 2024, 10:46:37 pm by KungFuJosh »
Offline Martin72
« Reply #13 on: July 18, 2024, 10:59:59 pm »
Hehe,
I had paid quite a lot for it, the thing is OK, but you can forget about the auto detection function.
In the meantime, I had built my own tester for OP amps.
(Kierkegaard)
Online KungFuJosh
  • TEAS is real.
« Reply #14 on: July 19, 2024, 01:38:42 am »
I haven't tried it yet, but a while ago I built this to test audio OAs and DOAs: https://www.fivefishstudios.com/shop/index.php?route=product/product&product_id=69
« Reply #15 on: July 20, 2024, 04:42:03 pm »
Gyro, mine just says "LCR-T3-H" on the back.
Thanks all, I was just trying to get an idea of the most popular form.
Cheers.
RJD
Online KungFuJosh
  • TEAS is real.
« Reply #16 on: July 20, 2024, 05:07:02 pm »
I think most of us on this site call that a collection. 😉
Offline Gyro
« Reply #17 on: July 20, 2024, 05:48:55 pm »
Cheers.
A quick look on ebay seems to show that the T3 has the same form factor as the T4, as far as I can tell anyway.
It sounds as if you have what you want anyway, whatever you decide to do.
Best Regards, Chris
