A few months ago, while going back to my office, I stopped dead in my tracks in front of a pallet cage full of T&M gear heading for disposal. Obviously they had to clear out an ancient electronics lab.
As I was limited in time (travel next day which still needed preparation) and am limited in space (rented flat, which I share with a female which inexplicably has other priorities) I had to severely limit my choices. So I did not take the 2 oscilloscopes (one 4-channel !) and did not even look up the specs or even remember the model, as that memory probably would have been too painful. I also did not rescue the 4 Fluke 8020A, as my TEA has brought several multimeters in my hands and I do not need another one, however unconvincing that may sound.
What I managed to rescue: HP3478A, HP8116A, Racal Dana 1991, Keithley 2410. You can see the stack before I moved it to the attic.
The HP3478A works as far as I can test, I had to get new button caps and had to replace the ram battery.
The HP8116A seems to work, the NiCd battery just started to leak.
The Racal Dana 1991 had the usual problem, nearly all switches dead, I had to replace them
The Keithly 2410 will definitely need much work. The power section does not work at all, perhaps the custom transformer is dead, it looks overheated.
