Do you have a way to test potential purchases at the swap meet?
Directional couplers are easy.
The incident port (or reflected port) will be terminated in a 50 ohm resistor.
A simple ohm meter check will find gross faults. The other thing you do in the case of the Narda couplers is you look for broken or missing paint, to see if they have been disassembled.
With the Bird attenuator you are taking a chance; unless you bring an ohm meter and measure the input and output ports. a 30 or even a 20 DB pad should look like 50 ohms at the ports to ground. Again look for signs of tampering. The only thing wrong with my attenuator is it is missing the four rubber feet.
The Bird attenuator cost me $40.00 US
The two Narde couplers cost me $10.00 US each.
I tested the attenuator when O got back here and it is fine.
The couplers I will test later in the week.
As long as the Bird is within a DB I am happy, that is good enough for the boys I go out with
It will sit on my 8640 and provide protection since I do a lot of work on gear that can transmit.
I can test the couplers to my satifaction using my sweeper. (again good enough for the boys I go out with)
I would love to have some of the HP dual directional couplers, however they are too hard to tell if they have been tampered with. The Narda couplers are good enough.
