Author Topic: List your test equipment "scores" here!  (Read 832824 times)
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
Re: List your test equipment "scores" here!
« Reply #1775 on: October 04, 2017, 03:14:47 pm »
Well, it remains to be seen if it will turn out to be a 'score' or a pig-in-a-poke, but I snagged a non working HP 8673C signal generator from a local evilbay seller for $103.  I figured it was worth a shot for that price, and local pickup saved $100 in shipping - the bloody thing weighs about 65 lbs (~30kg).  It powers up, but then does a waltzing decimal point thing on the frequency display.  I haven't gotten to poke at it and try anything so far, but from what the manual says there is a board that might be configured incorrectly, so I'll start with that.
Unfortunately, it is a special option version (H12) that apparently deletes the lowest band and modulation & sweep capabilities that most had, but the first order of business will be to try to get it working.  I can burn the other bridges as I get to them.
-Pat
Offline nanofrog
« Reply #1776 on: October 04, 2017, 07:49:59 pm »
Our company was closing down one of the labs.  I scored for free an HP 3478B meter, Tek 2330, Lecroy 9304 4 ch scope, couple of power supplies, Tek TM506 full with PS, counter, couple of DMMs and FG, and 4 shopping bags full of parts and hardware.
The price was certainly right
Paul
Great Score looks like you hit the Lotto. :)   :-+ :-+
Absolutely.  ;D You definitely earned the You Suck award for this one.  :-+
-Pat
Best of luck getting it in working order.  :)
Offline GreyWoolfe
  • NW0LF
« Reply #1777 on: October 04, 2017, 09:49:31 pm »
Paul
-Pat
Yup, YOU SUCK   :-+ :-+, enjoy the toys, hope everything works.
Offline rob.manderson
« Reply #1778 on: October 06, 2017, 10:02:27 pm »
Got an HP 3325A for $80 - includes option 1 High Stability Reference and option 2 High Voltage output.  I don't really need option 2 and I may disable it (instructions in the manual) but option1 was certainly nice to get.  Funny thing is I ordered it on Oct 1 and it was due for it's annual calibration on Sept 30th  :-DD
Of course there were problems - it lacked the power button and the shift button is not only missing - the entire switch has been smashed and bits of it floating around inside.  It's one of those heatstaked things and not really repairable.  So I ended up buying a *second* 3325A just to get the front panel assembly.  That one was $50!  The second one seems from the photos to be missing the output attenuator assembly.
Apart from the buttons issue the rest of the instrument (first one) works a treat.  So all in all I'm pretty happy and I now have a donor instrument to keep number 1 going.
Offline Jay_Diddy_B
« Reply #1779 on: October 07, 2017, 04:14:06 pm »
Here are a few pictures of todays score.
I found a General Technologies CM100 AC/DC Low Current Clamp Meter in like new condition at a Garage Sale (Trunk sale or Car boot sale) for $25.00 Canadian ($20.00 USD).
Link to the manufacturers site:
http://www.gtc.ca/Products/CM100.html
This appears to be the same meter as the AEMC CM605.
Link to the AEMC site:
https://www.test-meter.co.uk/aemc-cm605-low-current-dc-clamp-meter/
Pictures
The unit came complete with leads, instruction booklet and soft case (not shown):
Testing
I am lucky enough to a have Fluke meter calibrator, 5101B and the 5220A Transconductance Amplifier. This setup is perfect for testing these meters:
Ohms Range
The meter is strange in that it has a single ohms range with a full scale of 100k \$\Omega\$. It includes a continuity buzzer, but it beeps at several k \$\Omega\$ and below. The Ohms range does not auto range.
Voltage Range AC and DC
Similar to the Ohms function, there is a single range 0-600V for AC and DC volts.
There is poor resolution for low voltages.
Here is the 10V reading:
100V reading:
DC Current Clamp
This is the reason that I bought the meter, the high resolution DC clamp meter. The meter can resolve 1mA. I found the meter was sensitive to orientation, probably the earth's magnetic field. Moving the meter caused the reading to change by +/- 6mA after zeroing. Not too bad, but you need to aware of this.
10mA Reading:
1A Reading:
10A Reading:
Conclusions
The DC Clamp meter, the reason I bought the meter, is very good. The other functions are a little disappointing.
For $25.00 CDN it was a bargain. ;D
Regards,
Jay_Diddy_B
« Last Edit: October 07, 2017, 04:17:41 pm by Jay_Diddy_B »
Offline Jay_Diddy_B
« Reply #1780 on: October 07, 2017, 04:38:55 pm »
Hi Group,
Martin Lorton did a full review of the GTC CM100. It can be found here:
https://www.youtube.com/watch?annotation_id=annotation_440874&feature=iv&src_vid=pWCDPBwEDXE&v=1sq2WRGPABw
He draws similar conclusions about the functionality.
Regards,
Jay_Diddy_B
Offline Ysjoelfir
« Reply #1781 on: October 09, 2017, 11:01:16 am »
That's a rather interesting meter, even though it behaves somehow strange on everything except the amps range... Thanks for sharing!
Greetings, Kai \ Ysjoelfir
Online Ice-Tea
    • Freelance Hardware Engineer
« Reply #1782 on: November 17, 2017, 03:28:20 pm »
Oh, good, I thought I was gonna run out!
Offline Berni
  • Country: si
« Reply #1783 on: November 17, 2017, 04:09:35 pm »
Now that is a lot of infiniium scopes. How did you come across so many?
Online Ice-Tea
« Reply #1784 on: November 17, 2017, 04:20:04 pm »
Auction :D
Offline nctnico
« Reply #1785 on: November 17, 2017, 06:20:30 pm »
Auction :D
Any 54835/54845 in that stack? If yes then I know who to call for spare parts in case my one goes bad  ;D
Online Ice-Tea
« Reply #1786 on: November 17, 2017, 07:54:04 pm »
Nope, I've bid on some but didn't get 'm. Should still work for 'generic' Parts like PSU, display, procent board etc. And can't these  things be uphacked?
Offline nctnico
« Reply #1787 on: November 17, 2017, 08:22:00 pm »
Which models did you get? HP/Agilent seems to have made many different oscilloscopes in this housing.
Online Ice-Tea
« Reply #1788 on: November 17, 2017, 08:42:31 pm »
54825A and 54815A. Oh,and a 8560.And a R&S CMU200.
And a couple of probes. Two of which active 1.5GHz. And recovery diskettes still in the plastic!. And an old smelly keyboard.That too.
Offline nctnico
« Reply #1789 on: November 17, 2017, 09:50:39 pm »
Hmm 500MHz and only 32kpts. Perhaps the 54815 can be uphacked to 54825 (2Gs/s instead of 1Gs/s). IMHO these are nice scopes to look at high speed signals and perhaps EMC compliance testing to see which part of a signal has unwanted frequency content.
Offline AF6LJ
« Reply #1790 on: November 21, 2017, 01:17:19 pm »
Ya know, stock up while you can . :)
Sue AF6LJ
Offline AF6LJ
« Reply #1791 on: November 21, 2017, 03:40:36 pm »
Picked up some new (to me) gear last week.
Top to bottom.
Simpson 260
B&K Scope
LG Spectrum Analyzer, Looking for an English manual for it.
Motorola Service monitor (needs a lot of work)
Sue AF6LJ
Offline Neomys Sapiens
« Reply #1792 on: November 21, 2017, 11:42:16 pm »
Well it seems that I extended my range of TM500-modules into the waveform displays - while at the same time aquiring my first own analogue storage scope! Advertised as working and a picture to prove it - if not mishandled by the parcel beasts it should be minor work only! At 122€ definitely ok.
Update: it seems to be in working order and not to need a major refurbishment. Maybe alignment of the storage/precharge circuit at some point, because it gets a bit blurry when operating in storage mode.
But that might be an error on my side - I have to play with the settings some more.
« Last Edit: December 13, 2017, 09:28:52 pm by Neomys Sapiens »
Offline Johnny10
« Reply #1793 on: November 22, 2017, 01:54:40 am »
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline capt bullshot
« Reply #1794 on: November 22, 2017, 10:45:54 am »
Wow, this thing is old and crusty, but not as beaten up as my R2600B (http://wunderkis.de/r2600/index.html). This one was one of the starters of my TEA  ::)
Quote from: Neomys Sapiens
I was looking at this particular one too. I didn't bid because I'm kinda overflowed by my TEA atm. The TM500 scope modules are pretty, anyway ...
Offline AF6LJ
« Reply #1795 on: November 22, 2017, 01:10:13 pm »
It is old and crusty...
1982 vintage... Newer than my IFR FM/AM 1000S which spends more time broken than running.
It is going to be a project for next year, I have some Ham, and commercial gear I want to get on the air first. (Atlas 350XL and a Micom 2-ET).
For now I have enough to keep me busy....
I need to get the second HP-8569B going, the first is going to it's new home this weekend.
Sue AF6LJ
« Reply #1796 on: December 01, 2017, 11:30:57 pm »
Got an HP3456A for $100 including shipping.  It failed test 3, which is apparently a classic symptom of power supply problems.  Sure enough, the +5V rail was down to 3.5V (it did seem a little silly using an AN8002 to measure voltages inside this instrument!) and the ripple was horrendous.  Likewise for the +33V Rail - about 20V and horrible ripple.  The other rails seemed to be ok.
The new caps arrived an hour ago from Digikey and they're in.  I replaced all of the electrolytics in the power supplies.  The 3456A is now passing all tests.  Now to cobble up some way of verifying it's accuracy!  It never ends, does it?
The following users thanked this post: Macbeth
Offline Macbeth
« Reply #1797 on: December 01, 2017, 11:50:25 pm »
Well done. Of course your progression will be to the 3457A to verify your 3456A. You won't be satisfied. You will finally progress to a 3458A. Even that is not enough...  :-DD
The following users thanked this post: rob.manderson
Offline MadTux
« Reply #1798 on: December 02, 2017, 01:07:15 am »
HP-3456A probably is more stable than 3457A, 3457A is low cost version of the HP345X meters, while the 3456A is like an old HP3458A (at least in terms of build quality). You'll need a DVM with LTZ1000 in it to reliably check a 3456A. Welcome to the world of volt-nuttery ;-)
Offline Ghislain
« Reply #1799 on: December 02, 2017, 11:08:52 am »
An Agilent 53181A Frequency Counter with option 010, 030 and 060 in excellent working condition 8)
« Last Edit: December 10, 2017, 12:14:03 pm by Ghislain »
