Author Topic: List your test equipment "scores" here!  (Read 824764 times)
Offline guido
Re: List your test equipment "scores" here!
« Reply #1450 on: April 24, 2017, 05:44:31 pm »
Now you need these....  :P
Offline bitseeker
« Reply #1451 on: April 24, 2017, 06:00:16 pm »
Ooh, nice Panaplex displays on those 3500. :-DMM
Online Vgkid
« Reply #1452 on: April 24, 2017, 08:06:29 pm »
$20 each and half a can of DeOxit D5 later and voila! 2 working DP 8200 voltage/current standards!
Great score, they are in really good shape as well.
Offline AF6LJ
« Reply #1453 on: April 25, 2017, 01:27:52 am »
Nice score on the DP-3500s.. :)
Sue AF6LJ
Offline mtdoc
« Reply #1454 on: April 25, 2017, 04:21:47 am »
It's interesting that those DP 3500 DMMs have the same "Guard" terminal that is on their voltage standards. I'm not sure I understand its purpose on the DMMs. :-//
Offline guido
« Reply #1455 on: April 25, 2017, 05:31:10 pm »
I have the user manual if you are interested. It is explained in there. My HP3456A and Prema 5000 meters also have Guard terminals (so probably also explained in the manuals).
Note i had to replace all caps in these. They leaked badly! If your standards have the same brand (Illnois), replace. Some of these are from those meters:
Others came from other equipment, If you see those Rifa X/Y cap, replace also. They are smoke bombs and will go bang.
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #1456 on: April 27, 2017, 09:38:06 am »
Picked up a Tektronix TAS465 scope. Unit is in really great shape and owner said it was used very little.
Came with 2 sets of Fluke PM8918 10:1 probes (unopened)
And a Tektronix P6021A current probe.
Also came with a huge Pelican box.
150 bucks for all
Offline tautech
« Reply #1457 on: April 27, 2017, 09:53:13 am »
150 bucks for all
Hell of a score.
The Tek P6021 alone is worth $3k new.  :scared:
Offline AF6LJ
« Reply #1458 on: April 27, 2017, 12:07:13 pm »
150 bucks for all
Nice Catch  :-+
Sue AF6LJ
Offline rustybronco
« Reply #1459 on: April 27, 2017, 12:29:49 pm »
Not really excellent deals but good enough in my opinion
Via Ebay...
Tektronix TDS360 'scope $124.99
Tektronix CDC250 175 Mhz (TXCO) freq counter $55.00
Hakko 936 + I-run holder $21.57
Tektronix P6109B 100 Mhz probe $16.79
Tektronix P6117 200 Mhz probe (listed as a P6109B) $15.68
I'm certain the list will grow as time goes on.
Offline NewPerfection
« Reply #1460 on: April 27, 2017, 05:43:26 pm »
Picked up a Xantrex XHR 40-25M power supply that appears to never have been used.  Looks like the only time it was ever taken out of the box was to take pictures for the auction listing; there's not a spec of dust or dirt inside or outside.  Got it from a government auction for $170USD shipped.
It even came with the original manuals, including full detailed schematics, parts lists, and detailed descriptions of the function of each subcircuit.  I don't know if I can legally upload any of it because the manuals explicitly state proprietary/copyright protected and are for US government use only.
40V @ 25A continuous rated, 10-turn pots, remote voltage sensing, can be controlled externally with digital logic or analog input (resistance-based or voltage-based), all the good stuff.  Looks like it was manufactured circa 2000.  The US government must have paid a fortune for these.
I'm mostly excited because it's the first decent variable power supply I've had, and I think I got it for a decent price as well.
Aerospace engineer, electronics hobbyist, and father of four amazing kids
Offline james_s
« Reply #1461 on: April 27, 2017, 05:52:11 pm »
That thing is a beast! What is the voltage range it can do?
« Reply #1462 on: April 27, 2017, 05:54:53 pm »
0-40V and 0-25A.  Those are continuous ratings too.
Offline bitseeker
« Reply #1463 on: April 27, 2017, 06:40:31 pm »
150 bucks for all
Woah! That's a sweet score, Buddy. Looking forward to seeing it in upcoming videos.
Offline bitseeker
« Reply #1464 on: April 27, 2017, 06:49:14 pm »
Good score, NewPerfection, and welcome to the forum. These are great power supplies and don't take up too much space on the bench. I have one from the same series, an XHR7.5-130 that trades off voltage (7.5V) for more current (130A).
Offline james_s
« Reply #1465 on: April 27, 2017, 07:31:45 pm »
Dang, what would you use 130A at such low voltage for? Could be handy for electroplating, or working on big old TTL boards.
I have an old 5V 300A switchmode power supply somebody gave me years ago, I've never actually found a good use for it.
Offline HighVoltage
« Reply #1466 on: April 27, 2017, 07:39:56 pm »
For example:
I have an Agilent 6V 100A power supply and it works very well in charging Super-Capacitors to 2.7V
It is really something to see for the first time, a super cap take 100 A until it reaches almost 2.7V
With 6V, I can even have 2 super caps in series taking 100A to 5.4 V
« Reply #1467 on: April 27, 2017, 09:32:56 pm »
Thanks!  I've been watching the EEVblog channel for a long time and I listen to the Amp Hour every week, but I never got around to joining the forum.  Glad to be here!
Offline bitseeker
« Reply #1468 on: April 27, 2017, 09:56:14 pm »
A wall full of LEDs!
No, just kidding, although that'd be one possibility. I only really needed a bit more than 60 amps to calibrate my electronic load. The rest is just headroom. I have tossed around the idea of modifying it to have a couple of ranges in order to balance out the voltage/current ratio a bit more for more flexibility. 15V @ 65 amps would be nice.
Offline james_s
« Reply #1469 on: April 27, 2017, 11:10:00 pm »
The LED wall is actually not a bad idea, although distributing so much power at such a low voltage could be challenging.
If you want 15V at 65 amps the easiest way to get that is probably a hot swap server PSU. Most of them are 12V or a tad higher, 600-1200W is not uncommon, and they're very compact and well made.
Offline bitseeker
« Reply #1470 on: April 27, 2017, 11:40:42 pm »
Yeah, low voltage is not optimal for long distances. Of course, one could boost it for transmission.
 :-+ I've got one in the queue that died in an HP server. A quick peek revealed much complexity inside. I may start a thread although I seem to recall some already that might be similar enough. TBD.
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #1471 on: April 28, 2017, 12:06:22 am »
Hell of a score.
Thanks, I was quite surprised to get those probes at that price. From what I see on the internet used one are as much as 1500 bucks   :scared:
Nice Catch  :-+
Thanks Sue.
Offline james_s
« Reply #1472 on: April 28, 2017, 12:35:59 am »
Server PSUs are so cheap on ebay I don't think I'd even try to fix one that died. The ones I have were little more than the cost of shipping.
Offline tautech
« Reply #1473 on: April 28, 2017, 12:38:14 am »
Hell of a score.
Yep, I spent ~3 yrs watching eBay to get the 2 P6021's I've got and luckily I never paid more than 200 US for each including postage to NZ but that was a few years back. Now it seems everybody wants one.  ::)
One's got the terminator like yours and the other came with Type 131 amp IIRC but with of course with the US 110VAC only PSU. Luckily from another member I recently picked up the 230VAC PSU for a fair price so now I've got 2 and good to go. Better still, they even agree on measurements with each other.  :)
The manuals for them are good to have and easy to find on the net. Be careful with it, they're a little delicate and be careful not to overload it.
Even if you biffed the other stuff you still got a good bargain.  :-+
Offline bitseeker
« Reply #1474 on: April 28, 2017, 12:48:55 am »
Yeah, it's more personal curiosity than a mission critical operation.
