I got myself a Lecroy LC584AL (1GHz, 2Gs/s 1Mpts) scope from the broken test equipment asylum called Ebay. According to the seller it doesn't show a picture so it was cheap after making an offer. The display not working is not a problem because I'd replace the CRT with a TFT screen anyway. One of the reasons I got this old scope is that I want to sell my other (more expensive) Agilent scope but didn't want to be left without the 1GHz ability, some other features and last but not least: a second working scope. Unlike many scopes before the USB era the LC584 has a PCMCIA slot which should be able to hold a PCMCIA to compact flash adapter with a compact flash card. The compact flash card is equally usefull as a USB stick so file transfer between my PC and the scope should be painless.
This is the picture from the Ebay listing:
If my wife doesn't kill me when this thing arrives I'll take some pictures of the inside and (if the scope works) the TFT conversion.
The front PCMCIA slot on this scope will only work with a battery replaceable type SRAM card (max capacity 4MB). Unfortunately CF cards of any type will not work. Now if you are lucky the scope has the HD01 option installed in the back of the instrument which will accept PCMCIA ATA up to 512MB flash cards or a SDCard with a PCMCIA adapter. This series of LeCroy scope is basically a souped up 93XX series in a different cabinet with a color (Sony Trinitron type) CRT and a PowerPC based CPU card.
It used the same main acquisition card as the 93XX series. It was much faster and could sport a larger amount of processing RAM than the 93XX at the expense of a much larger and heavier cabinet. Still a great scope. When you are working on this scope do not run it without providing additional cooling if you have the covers off. Also do not be tempted to install a "quieter" fan unless it equals the same CFM as the one you are removing. If you overheat the A/D's and other LeCroy heat sinked parts there is no hope to find replacements as these scopes are long out of support.
Typical problems:
There is a thermal cutout switch in the power supply that is known to be an issue.
The power connectors that plug into the Main Acquisition PCB overheat
The usual bad capacitors in the PS. Replace with good quality Low ESR Nichicon, United Chemicon or Equiv. Watch out for the one that is on the printer board. Something like 3000uF. It's across the 5V supply (a blue Philips part) and if shorted the power supply will not power up. Replace it even if it looks good. I have seen many of them fail.
There is also a circuit in these scopes that had the design intent of automatically switching from 120/240. That circuit is problematic. There is a service note on this that can be found in the files section of the Yahoo! LeCroy_Owners_Group on Yahoo! Groups (please join).
Manuals and PS schematics can either be found there or in the LeCroy Manuals section at
www.ko4bb.com/getsimpleWatch out for conductive dust!
I hope you get the scope in good condition and have great success with it. Also conversion to an LCD may not be too hard if you can find one that fits as the interface to the internal Sony monitor is achieved with a standard internal VGA DB style connector.
Sam
W3OHM
Owner and Moderator of the LeCroy_Owners_Group on Yahoo! Groups and the back up group
LeCroy Owners Group on Groups.io
