Author Topic: List your test equipment "scores" here!  (Read 819843 times)
Offline Neomys Sapiens
Re: List your test equipment "scores" here!
« Reply #2725 on: August 12, 2020, 01:07:34 am »
HP 8642a, needs a new battery and the LCD backlight needs new bulbs. It will get white LEDs for obvious reasons. This is the 2nd unit I own.
HP8657a, fully functional afaict.
The bottom HP PSU I rescued from the scrap, a colleague of mine brought it into the office, it was private property, to have it join our regular scrap removal. Never hit the scrap pallet, straight into my car booth.
Nice haul. You are aware that the HP PSU is modified? (the jacks between the instruments are probably an aftermarket mod to bring the fully rated output to the front).
Online wkb
« Reply #2726 on: August 12, 2020, 06:22:48 am »
Yes, I know. The former owner put the black/red outlet on the front. Factory standard is outlets on the back. I have since installed some heavier gauge wiring between these outlets and the connection rail, it was a bit too flimsy to my taste.
Wilko
Offline wolfy007
« Reply #2727 on: September 15, 2020, 03:13:19 am »
Latest haul!
Offline TimFox
« Reply #2728 on: September 15, 2020, 05:39:38 pm »
The -hp- 8012 is a good pulse generator.  I had a strange problem with mine:  the pulse outputs are current generators designed to drive one or two 50 ohm loads, one of which is internal and switched in by a DPST reed relay (on both positive and negative outputs).  Somehow, my DIP relay had been installed rotated 180 deg, so the contacts still worked but the internal coil diode was backwards—the relay almost worked but was unreliable.  No sign of previous work, so it must have been a factory error.  Easy fix.
The following users thanked this post: wolfy007
Offline CalMachine
  • Metrology Nut
« Reply #2729 on: September 15, 2020, 07:06:33 pm »
Latest haul!
How have those Fluke 732B's been since you got them? :P
All your volts are belong to me
Offline 0culus
« Reply #2730 on: September 15, 2020, 08:11:47 pm »
Latest haul!
Neat pulser. It looks like the little brother of my 8082A. Really great little bits of kit, and the controllable transition times is a killer feature.
Offline wolfy007
« Reply #2731 on: September 16, 2020, 01:10:27 am »
The pulse gen looked like a neat instrument, intercepted from a trip to ewaste. Trigger out appears to be working but main output doesnt, so might need a bit of repair and renovation (aka capacitor replacements  :P ).
Actually the 732B have been continuously on for couple months now, after replacing all the schaffner IEC inline filters and batteries. Just started logging to see how stable they are. I can say the 732A I got earlier is looking very good so far, hopefully the 732B's will be also. Then on to calibration if all looks good.   :D
Offline 0culus
« Reply #2732 on: September 16, 2020, 01:45:48 am »
CuriousMarc on youtube did a repair on an 8082A...might be some useful information in his video if there is commonality between the two.
Offline wolfy007
« Reply #2733 on: September 25, 2020, 05:45:08 pm »
More meters...
Offline yo0
  • Country: mx
« Reply #2734 on: November 27, 2020, 03:58:22 am »
a perfectly working Genrad 1863 for the equivalent of about 35 usd, just needed cleaning
best regards
Pio
« Last Edit: November 27, 2020, 03:22:20 pm by yo0 »
Offline Johnny10
« Reply #2735 on: November 27, 2020, 12:23:18 pm »
Wolfy007, What does your lab look like?
You have been accumulating some nice equipment!
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline wolfy007
« Reply #2736 on: November 27, 2020, 01:37:48 pm »
Still needs much more sorting out, bit messier than I would like Im afraid, but slowly getting through repairs. Need to sell some extras at some point, got carried away with some things I bought, because you know 'bargains'...   ::)
Heres a couple pics of it from a few months ago, thankfully a bit of spring cleaning has cleaned/sorted it up a bit (and an old bench photo before the clean up).
« Last Edit: November 27, 2020, 01:47:49 pm by wolfy007 »
The following users thanked this post: Shock, xrunner, beanflying, Trader
Offline exe
  • self-educated hobbyist
« Reply #2737 on: November 27, 2020, 02:17:51 pm »
My new bench power supply: eez bb3. Well, not exactly new, I got it a few months ago, but only now I managed to finish it to somewhat workeable state. Still missing a power supply for one channel, that's why it says "error" on the screen.
Offline Johnny10
« Reply #2738 on: November 28, 2020, 02:31:27 am »
Wolfy007. Great looking Lab !
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2739 on: November 28, 2020, 03:01:15 am »
Ditto - fantastic setup.  :-+
Offline uski
« Reply #2740 on: November 28, 2020, 03:32:24 am »
Just scored a supposedly working Philips/Fluke PM6669 frequency counter on eBay for $20+shipping. Not bad.
The following users thanked this post: wolfy007, Trader
Offline wolfy007
« Reply #2741 on: November 28, 2020, 05:45:44 am »
Bargain!
« Reply #2742 on: December 06, 2020, 12:49:54 am »
I am hoping this will 'eventually' be a score. $2k AUD for a 3458A with 'issues' from the other side of the country :palm: Has the fairly typical ACal error and has been out of use for 8-10 years so a trip to Keysight will be in it's future. Also has an Error 202 to sort out. ETA late next week.....
Offline 0culus
« Reply #2743 on: December 06, 2020, 03:53:56 am »
Nice. Personally, I got a 3456A for cheap, and I also have a 3455A (though I hate it now that I have the fan-less 56A). It's enough voltnuttery for me.  :-DD
Offline Miti
« Reply #2744 on: December 06, 2020, 01:11:18 pm »
Saved this from a dumpster at work. Another cleanup day, a box covered in dust, on an obscure shelf, nobody knew what it was used for or when, so was declared garbage. Oy vey!!!  :palm:
« Last Edit: December 06, 2020, 01:14:51 pm by Miti »
Fear does not stop death, it stops life.
Online wkb
« Reply #2745 on: December 06, 2020, 01:17:29 pm »
It says what it is on the bloody box   :palm:
Offline Miti
« Reply #2746 on: December 06, 2020, 01:39:39 pm »
What’s a DMM?  ;D
« Reply #2747 on: December 06, 2020, 01:42:45 pm »
What’s a DMM?  ;D
What’s NI brand ?  ;)  :-DD
Offline Miti
« Reply #2748 on: December 06, 2020, 01:51:10 pm »
What’s a DMM?  ;D
Wait, is that the brand?  I thought it stands for non interlaced...
Offline PartialDischarge
« Reply #2749 on: December 06, 2020, 01:53:17 pm »
It is all very obscure and cryptic , NI USB, 4 wire SENSE, 6 1/2 digit DMM, Input....
