Author Topic: List your test equipment "scores" here!  (Read 833097 times)
Re: List your test equipment "scores" here!
« Reply #2400 on: April 17, 2019, 10:30:13 am »
Added some slightly more serious Linear oomph to the bench with this 22kg beasty. Aussie made and tough as old boots. 35V @ 5A x 2. My couple of beefy SMPS can go back to just R/C use. $100 AU pesos plus 1/2 a truckload of $ for freight or maybe a 5 hour round trip to pick it up.
Offline rastro
« Reply #2401 on: April 17, 2019, 12:51:25 pm »
I like the dual suitcase handles.
The following users thanked this post: Towger
« Reply #2402 on: April 17, 2019, 03:15:40 pm »
The handles  were always strange on them you finish up with 22kg sitting under the belt line :o These and the matching era Scopes by the same local manufacturer were standard Secondary School gear 30-40+ years ago.
Added a slightly random (for most) bit of test gear to my collection as well at $20 AU pesos with postage. Impressive specs over my cheap one I have had for years for outdoor R/C flying use. Far more useful and accurate for low speed airflow in industrial work.
The following users thanked this post: salvagedcircuitry
Offline markav2
« Reply #2403 on: April 18, 2019, 01:46:35 pm »
A few days ago I hit the mother load of equipment at auction. Paid a total of $205 for all listen equipment.
Fluke 45 Dual Display Multimeter $37
Hewlett Packard 66332A Dynamic Measurement DC Source $14
Agilent Technologies E3632A DC Power Supply $110
Kikusui PAB 18-1A Regulated DC Power Supply $7
HP 6825A Bipolar Power Supply/Amplifier Calibration:7/16/2013  $18.50
HP E3615A DC Power Supply, 0-20V, 0-3A; Calibration: 2/18/2000 $18.50
None of it was listed as nonworking so hopefully, when I'm able to get it in a home shop and do some testing it will all be good.
Offline Neomys Sapiens
« Reply #2404 on: April 18, 2019, 04:23:00 pm »
Especially the second and the second-last leave me speechless.
Offline bitseeker
« Reply #2405 on: April 18, 2019, 09:42:50 pm »
 :o
Offline innkeeper
« Reply #2406 on: April 19, 2019, 12:12:01 am »
Been so long since I posted my acquisitions, I'll have to trickle them out as I use them.
The current one I am cleaning up ... Tektronix 576 Curve Tracer :)
if anyone has tricks for removing that blob of aged epoxy off the aluminum, let me know
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
The following users thanked this post: Ysjoelfir, 0culus
Offline shakalnokturn
« Reply #2407 on: April 19, 2019, 12:43:05 am »
Philips PM 3214
Hameg HM 203-6
Beckman industrial 9016
The lot for 50€, they all need repair and cleaning.
The PM 3214 has had a quick power-on so far, not looking too bad overall, but after a 5 min warm the traces loose intensity, the H.V. sags (trace length diminishes) this gets worse by turning the graticule illumination up.
I was hoping for a bad C203, that seems OK in circuit, the pottings looks atrocious, so now I'm starting to dread a leaky transformer or H.V. multiplier. Will have to make some measurements.
Offline GregDunn
« Reply #2408 on: April 19, 2019, 05:39:57 am »
Many kinds of epoxy will literally crumble to pieces when subjected to soldering iron temperature.  I had a circuit board on which someone had dropped an ugly blob of epoxy - which incidentally was covering up a couple of components.  I used a normal sized soldering gun with a thin spade tip and gently scraped it away.  At a high enough temperature the epoxy just fell apart; by being gentle, I was able to remove nearly all of it without damaging the board or components.  Yours being aluminum, it ought to be possible to get all the blob off pretty readily; I had to be careful with the glass-fiber board itself.
Offline 0culus
« Reply #2409 on: April 19, 2019, 08:24:33 pm »
Tek 7904A with a 7A26, 7A19, 7B15 (hey might as well start getting stuff for a 7104  >:D ) and a 7B92A. I've got a few more plugins coming.
« Reply #2410 on: April 19, 2019, 10:33:01 pm »
Do you intend to buy this strange comparator plugin? Please do, and then tell me for what it is useful really!
In this case a Tek document just managed to cause a capital WTF moment in me.
Offline 0culus
« Reply #2411 on: April 19, 2019, 11:02:00 pm »
Which one are you talking about? Among the other plugins I'm going to be getting is another 7A26 dual trace amplifier. The 7A19 is a 600 MHz 50 ohm amplifier designed for reaching the rated bandwidth of the 7904A (500 MHz).
« Reply #2412 on: April 20, 2019, 02:34:26 am »
I was referring to the 7A13 differential comparator plugin.
Offline 0culus
« Reply #2413 on: April 20, 2019, 02:42:02 am »
Ah. I think there is one in the box of plugins the fellow is sending me. No experience with it yet.
« Reply #2414 on: April 20, 2019, 02:49:06 am »
When I read the app note for it, it seemed very drawn by the hairs to me. I could not see where the real purpose of the thing is.
Offline 0culus
« Reply #2415 on: April 20, 2019, 02:53:07 am »
I'll let you know what I find once I have one...in the meantime, just for grins I tried pushing the 7A19 and 7B15 a little. While the 7B15 is really intended to go with a 7B10 in a 7104 mcp CRT scope, it works quite nicely and I was able to get a stable trigger at 1.1 GHz. Beyond that the frequency response of the 7A19 (rated at 600 MHz) drops off precipitously to nothing.
The following users thanked this post: kj7e, Neomys Sapiens
Offline Berni
  • Country: si
« Reply #2416 on: April 20, 2019, 08:11:14 am »
Now that is a pretty darn fast analog scope.
Offline siggi
« Reply #2417 on: April 20, 2019, 07:31:16 pm »
It's a differential amplifier with decent bandwidth and a nice common mode range. At 1mV/DIV it'll cope with +-10V common mode, which comes out to 10000 DIV common mode.
You can also used it as a single-ended input amp with a massive offset. You could e.g. look at a 3.3V rail with DC coupling at 1mV/DIV in 100MHz bandwidth.
You'd be able to see minute ripple, but also slow "DC" drift, which you wouldn't be able to see with AC coupling.
« Reply #2418 on: April 20, 2019, 07:37:18 pm »
So there is no threshold or switching involved - the 10-turns or digital adjustment is just for the offset?
Offline siggi
« Reply #2419 on: April 20, 2019, 07:40:50 pm »
Yups - essentially you get to dial in a voltage and use it as input to either of the differential inputs, or you can both inputs for a differential measurement.
Offline eemil84
  • I am good at being bad since 2004
    • YouTube - Finnish garbage
« Reply #2420 on: April 20, 2019, 08:52:09 pm »
I got this HP54645A Oscilloscope for 45 euros from our uni. Last calibrated in '09 but seems accurate enough.
Made in 1996 in USA. It has 2 channels, negazoom and a sharp CRT tube.
It was "Broken". I just needed to clean the keys and glue one pcb in and it worked like new. I modded an usb port to it(sorry)
And I got a Hameg 20Mhz analog scope for free. from the 80's. Made in West Germany. I opened it up and it was in top notch condition. Nothing has leaked or broken. German engineering!  :-+
CRTs are cool!
I don't have any professional education in this field, but I still manage to go on. I can't do any math.
Offline ArthurDent
« Reply #2421 on: April 22, 2019, 03:06:23 pm »
This may not be a big score but I went to a ham fleamarket a couple of days ago. It was much smaller than I had hoped but there was one seller there who had, along with other goodies, several small SMPSs, most were new and still wrapped. I asked how much and he said $1 each so I just grabbed them all, not even checking their ratings. A lot of equipment uses small power supplies like this and sometimes it's easier to replace than to try to repair.
I was a little surprised when I opened one and saw the brand name. I'll have to check it out to see if it really meets specs!  8)
The following users thanked this post: kj7e, salvagedcircuitry
Offline kj7e
  • Damon Stewart
« Reply #2422 on: April 22, 2019, 03:19:44 pm »
I bet it has tremendous specs and its really great!
« Reply #2423 on: April 22, 2019, 05:36:37 pm »
Check twice. At least. And put the test records in a place where they can't reach them.
Offline bitseeker
« Reply #2424 on: April 22, 2019, 06:18:35 pm »
Wow, that's a good source for lots of jokes. :-DD
