Author Topic: LISN 50uH Solar Electronics 9252-50 Teardown  (Read 4263 times)
Offline JesterTopic starter
« on: September 21, 2016, 03:06:46 pm »
I was going to build a 50uH LISN, and then I spotted this one for less than the parts to build one.
Pretty old, the GE calibration stickers were intact until I opened it.
Offline Jay_Diddy_B
Re: LISN 50uH Solar Electronics 9252-50 Teardown
« Reply #1 on: September 22, 2016, 01:23:04 am »
Thank you for posting the pictures.
If I had to guess the schematic, I would guess this:
If you still have the unit open, may be you can confirm the component values?
Make sure that you protect your spectrum analyzer input, preferably a dc block and a limiter or as a minimum a high power 10dB attenuator.
Regards,
Jay_Diddy_B
« Reply #2 on: September 22, 2016, 02:28:21 am »
Regards,
Jay_Diddy_B
Good guess:
- the 4uF's are actually 5uF
- the 1k is actually 1k1, (only one) and is connected from the BNC out to chassis
- there is a 560k in parallel with the 5uF capacitors
- There is a 51r in the switch circuit
Good advive, I will use a DC block and attenuator, or perhaps add one internally to be on the safe side.
