Now my three main supplyes are good, I had to make some little adapters for the LM723 from DIL14 to TO100package, I couldn't get TO100ones, But my +120v and +48v rails are busted, I'm measuring +186volts at the +120v and 26volts at TP5 across C5 I have 78volts, but betwwen the negative side of C5 and GND I'm measuring -52 volts. Across C3 I have 186volt, and betwwen the negative side of c3 and GND I'm measuring -7.5volts. These measurments does not change id I disconnect the power tranies, the power supply is disconected from the rest of the circuits. All the transistors seem fine, what can cause this problem?
