Author Topic: Digital Multi-Meter to measure pulse of a flowmeter  (Read 441 times)
Offline xstarlogicTopic starter
  • Country: id
« on: September 06, 2024, 05:30:21 pm »
Hello all,
I need to measure the frequency emitted by the flowmeter. The flowmeter transmits data  0 to 12kHz with an amplitude of 17 DC Volt.
I have been looking into some digital multi-meter reviews. Most do not have a review regarding on frequency reading. If some frequency reading is included in the review, all use sinusoidal waveform of AC power source.
I do not want to use an oscilloscope, which will be more expensive. For safety reason, I wanted to carry less stuff climbing to 10 meter or above. and most instrument are using 4-20 DCmA, so it will be troublesome to carry lots of things while climbing up.
I've been looking at some low budget multi-meter brand available in my country, such as ANENG and ZOYI. Brymen is not available, UNI-T is available but most are expensive. Fluke is not my best choice. I am currently looking at ZOYI-102L but have no idea will the frequency work for 17 DCV.
I am newbie to electrical frequency, please provide me with basic explanation.
Many thanks to all
Offline HKJ
    • Tests
Re: Digital Multi-Meter to measure pulse of a flowmeter
« Reply #1 on: September 06, 2024, 05:38:45 pm »
Check my reviews, I do test the frequency input on DMM's:
Generally meters is not designed for sinus waveforms, but for square wave. If the amplitude of the sinus is large enough it will be counted.
Offline HKJ
    • Tests
« Reply #2 on: September 06, 2024, 05:44:56 pm »
If you want to count the actual number of pulses, you have a problem. Very few meters can do that, I only know of some Gossen, but they are very expensive.
Offline Phil1977
« Reply #3 on: September 06, 2024, 05:50:06 pm »
Is the FNIRSI SG003 / SG004 in your budget range? These are low-cost process calibrators, so their main functionality is generating signals. But they also have a quite good input side with frequency and PWM display.
They also allow you to choose between logic signal or open collector detection - that´s a feature I´ve never seen at any DMM or frequency counter.
And they´re small - perfect for field use.
  • Country: id
« Reply #4 on: September 07, 2024, 04:07:06 pm »
Where to see your review? I'm still new around here, and may get lost very easy.
I think pulse produced by flowmeter is a square waveform as they are intercepted by DI module of PLC.
No, I'm not looking for calibrator or generator. Please read my question carefully.
« Last Edit: September 07, 2024, 04:10:27 pm by xstarlogic »
Offline HKJ
    • Tests
« Reply #5 on: September 07, 2024, 04:10:57 pm »
Click on the globe under my name will bring you close.
A more direct link: https://lygte-info.dk/info/indexDMMReviews%20UK.html
Offline Phil1977
« Reply #6 on: September 07, 2024, 05:15:53 pm »
Please read my answer carefully. The SG03/04 have a meter and a generator function. And the meter is capable of measuring frequencies, counting pulses and measuring PWM.
Offline BeBuLamar
« Reply #7 on: September 07, 2024, 06:31:20 pm »
I don't know I would assume all DMM with frequency measurement function can do that. I have used the following DMM to measure frequency Fluke 87V, 189, 287, 289, 45 and all can measure pulses. Although the kind of pulses I have are either 5V or 12V or 24V (not 17V but I don't think 17V would make a difference). And yes they are all square wave pulses.
Offline HKJ
    • Tests
« Reply #8 on: September 07, 2024, 09:01:21 pm »
There are differences in how they trig, some requires a zero crossing, some do not.
Offline DaneLaw
« Reply #9 on: September 07, 2024, 09:34:29 pm »
They are quite versatile, though only the SG004A got the frequency reading (in/out) just as MR9270S, while SG003A only got (out).
Flow meter example from +9.10min
The following users thanked this post: Someone, 2N3055, Phil1977
Offline BeBuLamar
« Reply #10 on: September 08, 2024, 12:02:54 am »
All of the signals I mentioned are not zero crossing. They are 0 to 5, 12 or 24V pulses.
