Does anyone have good experience with LED replacement of the CFL Tubes in a Tek TDS3000 series scope?
I work on an instrument that uses the same display. It is commonplace for the instrument to be dropped and the tubes broken. The source of the replacement tubes has run dry for the most part, and an LED upgrade would so much nicer, maybe.
Can anyone point me to a driver PCB and LED Strip that is appropriate for these displays? Without looking, the DFL tubes are about 6" long. They are dim-able in the instrument in use, but that capability could be eliminated if need be.
There are probably numerous options, but I would prefer experience and not have to engineer a solution from scratch. At least point me towards parts that should work - lol.
Thanks
