Hi there,
I just collected a non working LeCroy WaveSurfer 24MXs-B.
When turned on, the front panel buttons light up for 1 sec, fans do spin and that's all.
No beep, no boot, nothing except the fans and LCD backlight.
I connected an external VGA monitor, but no signal.
I read that the PSU on these WaveSurfer series was often an issue.
Not this time. Mine is OK, I tested all voltages (+3.3V, -3.3V, 5V, +12V, -12V, -6V) all measured OK.
I also tried powering the motherboard with an external ATX PSU and a VGA monitor.
It does not boot, and still no VGA signal. BIOS 3V battery is OK.
Conclusion, the motherboard is Kaputt!
I also read that this mobo is unobtainium.
Does anyone have a suggestion for a replacement solution?
The board is the first series with PS/2 port and PC104 slot.
Regards,
tppc
