Author Topic: LeCroy WaveRunner 6000(A) LCD  (Read 513 times)
Offline darkstar49Topic starter
« on: October 29, 2022, 03:36:33 pm »
nothing groundbreaking, but as I was just busy replacing the motherboard of 2 6100A's (with some from Kontron), I though I'd publish the SDVO/LCD pinout, for those who'd need to make their custom LVDS cable, too...
I used a 20-wires pre-crimped cable, but some other LCD's/mainboards may require a different number of wires.
the LCD connector on the front panel board of the (A) series is compatible with a Hirose DF19-20 connector, the backlight (inverter) connector (on the cable) is JST S5B-PH 5-pin female connector (I didn't use it, and soldered the power supply lines from the motherboard onto the wires directly)
« Last Edit: October 29, 2022, 03:41:07 pm by darkstar49 »
The following users thanked this post: 2N3055, Martin72, sstefan80
