Hey All,
I have a Wavesurfer 424 and did an upgrade to an SSD (Transcend TS32GPSD330) and had 2GB of RAM laying around that I put in as well. Boots up fast but for some reason, it displays the "factory calibration data has been moved" and none of the settings seem to have been saved.
It appears that if I do make some adjustments, shut down the scope then start it up again, the settings are saved. All of the cal data is there on the D: drive so I think it's just because of the drive change.
It seems the registry key
HKEY_CURRENT_USER\Software\LeCroy\Maui\ShowCalibrationDataError should be deleted and everything will be back to "normal". Can someone confirm this?
Edit: Found the solution to the serial decode menu not showing as @RedCali had the same issue:
https://www.eevblog.com/forum/testgear/lecroy-options-recovery/msg3352494/#msg3352494And one more thing - I can't seem to get the serial decode option to show up. I have the following options set:Software options: DECODE_MEASURE DFP2 EMC ET I2C JTA2 MSURF PMA2 XDEV XMAP XMATH
What am I missing here? Thanks!
