Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
LeCroy DDA-5005A probe options for full 5GHz bandwidth
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LeCroy DDA-5005A probe options for full 5GHz bandwidth (Read 271 times)
suspension
Regular Contributor
Country:
on:
June 16, 2024, 03:45:28 am »
Hello
I am thinking of buying a LeCroy DDA-5005A DDA to be used as an oscilloscope. Used units in ebay don't come with probes. I read in this forum that the connector type is different: more info in here:
https://amplifier.cd/Test_Equipment/LeCroy/DDA5005A_XXL/DDA5005A_XXL.html
Few questions:
1. If I were to measure up to 1GHz, can passive probes be used?
2. To go to max bandwidth, should I use active probes? Or can passive probes be used still?
3. Are there non lecroy probes that connect to the scope directly without a BNC converter?
4. The input is 4V peak to peak. Is it possible to protect this input from accidently applying higher voltages? say 12 V?
Thanks
S
Logged
smaultre
Regular Contributor
Country:
Re: LeCroy DDA-5005A probe options for full 5GHz bandwidth
Reply #1 on:
June 16, 2024, 07:49:44 am »
This class of oscilloscopes used only as HF stuff. They have 50Ohm input, uncompatible with BNC type 10:1 probes.
You can use passive matched-line 50Ohm probes stuff, but only 4V peak to peak.
Or buying Lecroy active probe with 5:1 or so..
Logged
Start a new life here!!!
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
