Author Topic: LeCroy 9400 Screen Update Problem?  (Read 2306 times)
Offline corrado33Topic starter
« on: October 12, 2013, 12:57:11 am »
Hi all,
Just a quick one here. I've been playing with a LeCroy 9400 recently and was wondering something. Every once in a while when I'm looking at a signal, some relay will switch in the device and the screen will pause (aka stop updating). After 2 or 3 seconds, it'll continue it's normal operation.
Is this normal? Is it a known fault? What could be going on? A quick google search didn't turn up anything.
Offline digsys
    • DIGSYS
Re: LeCroy 9400 Screen Update Problem?
« Reply #1 on: October 12, 2013, 01:20:42 am »
It's just the system re-calibrating for temperature (amongst other variables). Once it is warm, it should do it less and less.
If it doesn't stop re-calibrating after a warm up period, then it may need factory / lab calibration, or there's a aged(?) component,
like one of mine has. It's a good thing :-)
« Reply #2 on: October 12, 2013, 01:37:30 am »
Very cool! I usually don't have it on very long so that could definitely be it. The scope itself does have a few issues (like I can't get the B input button to work...) but now I know nothing is seriously wrong, so that's good!  :)
Offline marshallh
    • retroactive
« Reply #3 on: October 12, 2013, 02:41:26 am »
Yeah, seems to be a hallmark of Lecroy scopes.. my 9374C does also, albeit less so after about 30mins of being on (probably because the room around it has increased by 10 degrees in temperature)
Verilog tips
BGA soldering intro
Offline digsys
    • DIGSYS
« Reply #4 on: October 12, 2013, 02:45:45 am »
You can find the service manuals on the web. There's a couple posts on these forums with the links, but shouldn't be hard to find.
