Author Topic: Tektronix 464 Bright Screen  (Read 683 times)
Offline sverzijlTopic starter
« on: May 08, 2020, 10:09:04 am »
Hi All,
I've dusted off my father's old oscilloscope and I believe there may be an issue with the screen as it appears to illumination across the whole screen. Sometimes I turn it on and everything is fine. Other times it has flashes of light. Other times permanently on.
Any thoughts on what could be wrong? It has sentimental value so I'd love to be able to get it working!
Offline wn1fju
Re: Tektronix 464 Bright Screen
« Reply #1 on: May 08, 2020, 12:12:00 pm »
Almost looks like it is set to storage mode.  Make sure the "non-store" button is depressed and also hit the "erase" button a couple of times.  Ultimately, you
might have to spray some contact cleaner in the switches if the behavior is intermittent.
The following users thanked this post: sverzijl
« Reply #2 on: May 08, 2020, 02:38:36 pm »
Brilliant - non-store was not active!
Thank you very much.
Offline Gyro
« Reply #3 on: May 08, 2020, 04:30:59 pm »
It would be worth watching the storage modes video linked on the 464 TekWiki page and finding a downloadable copy of the manual...
https://w140.com/tekwiki/index.php/464#Manuals
http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=Tektronix/Tektronix_-_464_Storage_Oscilloscope
« Last Edit: May 08, 2020, 04:33:25 pm by Gyro »
Best Regards, Chris
