Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
'uCurrent' circa 1976
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 'uCurrent' circa 1976 (Read 1061 times)
srruhl3701
Newbie
Country:
on:
August 13, 2020, 09:13:46 pm »
While browsing old electronics magazines, I came across a construction project of a miliamp volt meter accessory. It uses a CMOS op amp, and also can measure current with 1 nA full scale on the 1 volt range of the meter.
It is designed for analog meters with 1k Ohms/Volt or greater.
https://archive.org/details/197607PopularElectronics/page/n3/mode/2up
Logged
SilverSolder
Super Contributor
Country:
Re: 'uCurrent' circa 1976
Reply #1 on:
August 13, 2020, 10:03:55 pm »
I guess it would need a zeroing pot, if it is not based on a chopper amp?
Logged
srruhl3701
joeqsmith
Super Contributor
Country:
Reply #2 on:
August 14, 2020, 01:30:53 am »
Are you referring to the "millivolter" that allows a volt meter to read millivolts?
Logged
How electrically robust is your meter??
https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Solver64 Dropbox
https://www.dropbox.com/scl/fo/t4m8ws3oxmy31b84duiqp/ACDdAhRudlB8HQtL_I1ne-4?rlkey=1brzha3r8l7itnt9s7qhmp0ey&st=mouo3wyt&dl=0
srruhl3701
Newbie
Country:
Reply #3 on:
August 14, 2020, 02:01:58 am »
Yes, it also has selectable shunts to use for reading amps.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
