Hi Folks,
There are clues in these forums discussing the liberation of the SDG1000 series (and newer) function generators.
I've collected all the scripts and instructions, but I'm confronted with the disparity that when I issue a "MCBD" command to my SDG1025, I an returned with a 32 character result, which is actually just the just a 16 character code repeated: just like "NZ2CMUK55SMTBP3NZ2CMUK55SMTBP3"
When I've used the script lingering around here, I can't achieve the same 16 character string that I see repeated.
Am I missing something? Is the SDG1025 not one that can be liberated?
Thanks folks!
