I have told my fellow techs about these meters. As a reminder, our use is low resistance and continuity. There might be a time when voltage checks are needed but the resistance accuracy is important. I use mine with the Brymen leads that Frankie sells and the meter is very accurate, the OEM leads are not good quality. Size, for me, was another consideration, the smaller the better to fit in my tool bag. I know there are negative comments about the meter, But as Russ says, it's a $24 meter. If you want great specs, great viewing angles, solid stands, quality test leads, etc, buy a more expensive meter. As long as you take into consideration that it is a $24 meter, it will serve your needs fairly well. I have much better meters, but for my particular needs, there is no better bang for the buck.
