Author Topic: Scope probes as supplied by Rigol for the low end scopes, a discussion.  (Read 47444 times)
Offline Pjotr
Re: Scope probes as supplied by Rigol for the low end scopes, a discussion.
« Reply #75 on: January 25, 2015, 02:20:56 pm »
Yes, we are proving that very cheap probes are crap anyway  :D
My point was that with a faster source you will see even more ringing from the poor thing.
Offline sync
« Reply #76 on: January 25, 2015, 02:44:36 pm »
Anyone tried the Rigol RP2200 Probe? "Thats not so good Al..." (Weezer)
The difference in time, is due to the length of the probe cable.
I am not to happy about the RP2200 Probes...
I had the same result in my test. The RP2200 overshoot.
https://www.eevblog.com/forum/testgear/the-possible-hidden-cost-of-the-ds1054z-bandwidth-upgrade-hack/msg573856/#msg573856
Offline miguelvp
« Reply #77 on: January 25, 2015, 08:25:49 pm »
That picotech 60MHz probe beats them both, I know you don't have the model number posted, but if you find out what is it please share.
Offline dr.diesel
« Reply #78 on: January 25, 2015, 08:51:24 pm »
Has anybody mentioned the rubber/plastic on the ground alligator clip?  The dang thing is stiffer than a wedding dick, very difficult to squeeze and release.   :--
Offline electr_peter
  • Country: lt
« Reply #79 on: January 25, 2015, 09:41:03 pm »
First the pictures of the generator en the probe connectors :D
Blackdog, what adapters did you use to connect scope probe tips to the BNC? Do you know a source in EU or eBay?
I searched for such adapter pieces but could only find very expensive HP/Agilent/Tek adapters.
Offline Pjotr
« Reply #80 on: January 25, 2015, 09:59:30 pm »
Farnell has some sold separately from Tenma for about €6,-. But those adaptors are not universal because the size of probe tips differs. They fit or they are too big: Loose gnd contact, but still somewhat usable. Or they are too small and don't work at all.
« Last Edit: January 25, 2015, 10:01:03 pm by Pjotr »
« Reply #81 on: January 26, 2015, 12:13:42 am »
All the probe tip to BNC adapters I have have come with the better quality probes I have.
They are not normally included with probes that come with entry level DSO's.
And yes they can be different sizes for some probe tips where the GND sleeve connects to the adapter.
Offline aargee
« Reply #82 on: January 26, 2015, 06:57:12 am »
I agree, the alligator clip is as stiff as dead dingos donger.
Not easy, not hard, just need to be incentivised.
Offline EEVblog
« Reply #83 on: January 26, 2015, 10:36:36 am »
Mine have all come bundled with expensive probes, designed to fit those probes, they are quite loose on the Rigol probes, often having to hold them in place by hand.
Offline Pjotr
« Reply #84 on: January 26, 2015, 11:29:16 am »
The Farnell order code for the Tenma adaptor is 2414908. Given the price you can give it a try.
« Reply #85 on: January 26, 2015, 06:51:04 pm »
Exactly.
Do they give an probe tip diameter that it fits?
Anybody mic'ed up the Rigol probes?
« Last Edit: January 26, 2015, 08:53:49 pm by tautech »
Offline Pjotr
« Reply #86 on: January 26, 2015, 07:35:48 pm »
The data sheet states 5mm: http://www.farnell.com/datasheets/1801350.pdf The ground sleeve of the Rigol probes is about 4.6 mm. But since it looks it has "springy" ground contacts it can be adjusted somewhat I guess.
Offline soren
« Reply #87 on: January 26, 2015, 08:50:01 pm »
Testec probes also come with a BNC to probe tip adapter.
Their probes start at EUR 15.70, so that's another possible source for an adapter:
http://www.reichelt.de/Probes-and-Accessories/2/index.html?&ACTION=2&LA=3&GROUPID=4043&LANGUAGE=EN
Offline Pjotr
« Reply #88 on: January 26, 2015, 09:02:27 pm »
I have a few of them and those look exactly the same as the Tenma. The Testec adaptor is also a few tenths of a mm too wide  for the Rigol probes and doesn't make a good contact. Better invest into the Testec HF series  or similar then directly :D
Offline LightagesTopic starter
  • Canadian po
« Reply #89 on: January 26, 2015, 09:24:38 pm »
Those Testec probes look like good value, IF they live up to their specs and are good quality.
