While I don't speak for them, what they have done does make some sense to me.
You've used a split rail + argument to support your POV yet in Ch 2-3 Series mode one can pull 0V from the center connection for dual tracking supply needs without any need for external cabling and only 2&3 support Series and Parallel modes and Sense.
As Ch 1&4 don't provide Series or Parallel modes or Sense it's not logical they need be grouped together even for split rail use as they can't be Series'd for dual tracking supply use.
This does however bring additional thoughts forward, should Ch 1&4 have instead been paired and given Series and Parallel capability some major changes to the design and UI would be needed, otherwise how would one know which channels were being Paralleled or Series'd ?
@Furna
What is the display indication when Ch 2&3 are used in Series and Parallel modes ?
The SPD3303X and GPP4323 both allow creating a Dual Voltage Tracking Supply utilizing the Series Mode on CH1 and CH2 without any "extra" cabling also, altho the SPD3303X doesn't read the current thru/from CH2 properly (serious flaw IMO). Example drawing a different current from CH2 while in the Series Mode doesn't show in the CH2 current display. Apparently this is just displayed as a replica of the CH1 current
The GPP4323 reads this condition properly and displays the correct current drawn from both CH1 and CH2 while in Series Mode, whether thru or from both channels or some current "tapped" off from CH1 or CH2.
This dialog has allowed us to discover a potential issue with the SPD3303X that we didn't know, as we don't recall ever seeing this discussed before. Maybe others can do this test in addition to the ON/OFF characteristics?
If you or Furna have the time please check the SPD4000X in Series Mode and see if CH2 and CH3 display the correct current drawn respectively. Just place a resistor across either CH2 or CH3 and see if it registers properly on the respective channel display, then attach across the full series span of CH2 and CH3, this should show twice the current and displayed in both channels as flowing thru both.
Anyway, good discussions
Best
