Author Topic: SIGLENT SDS1102CML - First Impressions  (Read 103129 times)
Offline v81
Re: SIGLENT SDS1102CML - First Impressions
« Reply #125 on: March 28, 2015, 06:16:45 am »
For the Aussies-
Got word from the blokes @ ocau.com that this model is on sale @ Rockbys at the moment for $395 inc GST
I'm new to scopes, but looking a the screen shots it appeared this unit has a rather low res screen?
I have little experience, bar from my 1st scope bought a few days ago (for $130 more than this!) DS1054Z @ 800 x 480
Offline David Aurora
« Reply #126 on: September 20, 2015, 11:43:38 am »
Just went through the firmware update process to keep mine up to date (5.01.02.32) and I cannot for the life of me find the cfg file that's supposed to be part of the download and part of the update process according to the instructions. Am I missing something here? Firmware update seemed to work, scope is running and system status shows the latest firmware, but I can't complete the update config part of the instructions as I can't find the file!
« Reply #127 on: September 20, 2015, 07:13:11 pm »
AFAIK the cfg file is only required if you are updating FW from a much earlier version.
If your system status is showing the version you have just installed then all is well.  :-+
« Reply #128 on: November 10, 2015, 08:17:34 pm »
Only just saw this, thanks mate :)
Offline arivel
« Reply #129 on: January 13, 2022, 07:28:59 am »
Hello .
sorry if I resume this post after some time.
I went to read the SDS1102CML + datasheet (the improved version) and there is written real time sampling 1GSa / s. is this for each channel or in total for 2 channels? . does it have 2 converters or just one?
« Reply #130 on: January 13, 2022, 07:39:52 am »
Hello .
Single ADC in these. Sampling and memory depth is halved when both channels are active.
« Reply #131 on: May 05, 2022, 09:59:32 pm »
Does anyone know what the last update for this scope was and where to find it? Mine barely gets used so I tend to forget about it, but lately I turned it on a few times and there definitely seems to be a couple quirks with the firmware version it has on it. When I search for it though all I can find now is firmware for the + version which I assume isn't going to work on the old version?
« Reply #132 on: May 05, 2022, 11:33:25 pm »
SDS1000CML_CNL_5.01.02.32 is the last version I have from July 2017.
Attached as a TXT file so remove the TXT extension before installing to scope.
The following users thanked this post: David Aurora
« Reply #133 on: May 06, 2022, 06:51:20 am »
Thanks, according to my reply in this thread from 2015 that's the version I updated to, so I guess that was the end of the line, bugs and all  :-//
I might even try re-installing later just in case that's the issue
Offline gavenkoa
  • Country: ua
    • Home page
« Reply #134 on: December 08, 2023, 09:45:14 am »
tautech provided firmware is identical to what I downloaded from Web Archive, if you are afraid of integrity my calculations:
# md5sum SDS1000CML_SSP_V100R005B01D02P32.ADS
d6409e48b26abc37f4f99ea49409ef09 *SDS1000CML_SSP_V100R005B01D02P32.ADS
# sha256sum SDS1000CML_SSP_V100R005B01D02P32.ADS
b2907a3850bb4f09e8fe27db7f5b2353f01953acdc16aa28d02e0ee1e190299c *SDS1000CML_SSP_V100R005B01D02P32.ADS
Some archeological digging led me to the latest page the SDS1102CML is mentioned as discontinued product on Aug 2016:
https://web.archive.org/web/20160809134722/http://siglent.com/ENs/prodcut-detailxx.aspx?id=27&tid=1&T=2
The firmware is still available in 2018 at (so I assume it is the latest available version):
Version: 5.01.02.32 | Published:2015-07-09
It is downloadable from the page:
https://web.archive.org/web/20180713015239/http://www.siglent.com/ENs/prodcut-gjjrj.aspx?id=-1&tid=1&T=1
Two direct download links:
https://web.archive.org/web/20150908034130/http://siglentamerica.com/download/software/SDS1000CML_SSP_V100R005B01D02P32.rar
https://web.archive.org/web/20180713015239/http://old.siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SDS1000CML_SSP_V100R005B01D02P32.rar
